383 engine kit help
Old Dec 30, 2009 | 08:17 PM
  #41
STL94LT1's Avatar
STL94LT1
Boy, the recommendations from Comp Cams can really vary from person to person!!
Old Dec 30, 2009 | 08:20 PM
  #42
Pete K's Avatar
Pete K
Originally Posted by C4vettrn
Ok guy's here is what Bryan from Comp Cam had me go with, let me know what you think. Also these numbers are with 1:5 rockers which he seamed to think I should stick with. It seems the lift is a little low?
276HR12
intake exhaust @ .050 112 LS
224 236 duration
502 510 lift
Looks good. Tweak the lift by using the rocker arm ratio that best suits the heads flow.
Old Dec 30, 2009 | 09:08 PM
  #43
C4vettrn's Avatar
C4vettrn
Thanks! I will probably go with 1:6,s do to the fact I think Advanced Induction or Gole engines will be doing my heads i.e. bigger vavles and porting. they should be around 185-190cc when finished. The extra lift would give me 532 & 540 aprox.
Old Dec 31, 2009 | 04:37 AM
  #44
ndanl's Avatar
ndanl
i like this thread
Old Jan 2, 2010 | 02:41 PM
  #45
C4vettrn's Avatar
C4vettrn
Default pin removal help!
Whats the best way to get the crank and cam pins out without boggering them up to much? The cam pin drives the opti and the crank pin is for the timming gear correct I believe. I pulled with pliers but they seem pressed or frozen and I don't want them marred.
Old Jan 2, 2010 | 02:52 PM
  #46
Pete K's Avatar
Pete K
The cam will come with a new pin. To remove the crank snout keys, just use a hammer and drift to tap the inside edge of the key down, then use the punch to tap the opposite side up, rolling the key out.
Old Jan 2, 2010 | 03:57 PM
  #47
BLOCKMAN's Avatar
BLOCKMAN
I want to build a 383 around 450hp max. There are so many kits where do I begin? I was hoping some of you guys who have already done this can chime in. Some say forged some say not needed? I was thinking cast crank, I beam rods and forged pistons? The kits are unlimited. does anybody have a kit part number they used with good results? I don't need the best parts made nore do I want junk somthing in the middle quality wise (remember 450hp max)
This is a 92 LT-1 that will need a .030 oerbore. I would like as complete a kit as possible also plan on reuseing stock flexplate and just remove balance weight.
Scat makes a crank for a 6.0 rod that is internally balanced P/N 935037506000L Their I beam rod with 7/16 bolts has alot of cam clearance and we have been partial to the Mahle piston and ring kits can be bought reasonable as well.
You are better off to buy your parts and have a shop you trust balance the rotator as I have been through some pretty bad balance jobs.
We have always used Forged rotator with our builds and try to stick with the Callies line of products and so fa no problems.
We have been offered deals on some cheap forged 275.00 dollar cranks that don't size worth a shyt that aren't straight, journals not round ETC.
So I try to go with a quality parts that don't come back with problems.
On the dyno we have seen more of a gain just using 1.6 rockers on the intake a leaving 1.5 on the exhaust.
Old Jan 3, 2010 | 02:18 PM
  #48
C4vettrn's Avatar
C4vettrn
Default Aligning main bearings ?
Can you guys help clearify somthing my engine manual talks about?
They say to install the crank and push it to the rear then to the front of the engine to align the main bearings? I have never heard of this but it makes sense. How much tourqe should be on the cap bolts when doing this ? I wouldn't think much? thanks in advance.
The machine shop had a metal gasket that feel out of the oil filter housing that I missed when tearing the engine down. My Fel-Pro gasket set came with a fiber gasket for this area. do I use both or the new fiber or reuse the old metal gasket/shim?
Old Jan 3, 2010 | 02:22 PM
  #49
BLOCKMAN's Avatar
BLOCKMAN
That would be to set the thrust if there was no dowel pin used to align the rear cap.
Old Jan 3, 2010 | 02:37 PM
  #50
C4vettrn's Avatar
C4vettrn
Can you state the correct procedure, The manual is somewhat vague on the exact steps,How much tourqe is on the bolts? hand tight? is there any measuring of side clearances after? THANKS!
P.S. My new manual explains it in more detail thanks!
Old Jan 6, 2010 | 05:03 PM
  #51
C4vettrn's Avatar
C4vettrn
Default Degree wheel?
I went out and bought a performance manual for chevy small blocks, I have a factory engine manual but if your not a mechanic it's not that helpful other than showing the steps to take it doesn't give much detail on each step. I took my new oil pump apart a did a buch of dremel work on all areas the oil flows, cleaned up the nicks/burs on the gears and polished them some then I took a little meat of the cover with emery cloth on a flat serfuce to make the tolerances a little tighter.
My next questions are:
1. Is a degree wheel dial-in of the TDC necesary on computer controled cars OBD-I & II. Doesn't the ECU compensate and adjust itself to correct timming?
2. Is it recomended to broach the balancer hub on high performance engines do to slippage? Is reusing a 135k balancer (looks in good cond.)
OK? If not what is the reccomended balancer and do they come broached?
3. What is the best way to plug the hole in the timming cover for guys running dual roller timming chain?
4. Can I run my stock oil pan and factory baffle on a stroker motor?
Old Jan 8, 2010 | 07:40 PM
  #52
C4vettrn's Avatar
C4vettrn
Default Ttt
Ttt!
Old Jan 8, 2010 | 07:44 PM
  #53
Pete K's Avatar
Pete K
1) Degreeing a cam has nothing to do with ignition timing, so yes, you must do it.
4) Stock pan and baffle work, but you have to smack a few dents in it with a ball peen hammer to clearance for the rods.
Old Jan 14, 2010 | 10:33 PM
  #54
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
C4Vette, how's your project coming?
