My '96 hates me.........
There will be one difference other than any changes on the car though. All of the other runs were done when it was warm. Sometimes very warm and humid. It'll be below freezing in the morning. Good for Horse power but not good for Weav!
It is isn't it!
Last year sure went out with a bang with this car so I figured I was due a luck change.
I have the Stainless Works 1 5/8 headers on the car at the moment. Would it be of any advantage to change over to a 1 3/4 header? I know this is a heated subject so you can PM your answer if you like. Not wanting to start a war here.
LE said the 1 5/8 would hurt me. You agree? My thinking is they do. The torque fell off really fast.
The headers, well, I went with 1 3/4 as they were for future mods, prior to even getting the 396.
I personally would recommend 1 3/4 when you do the heads.
It would be great if you could do a dyno with the 1 3/4 prior to the heads
PS, I think the D44 will change your dyno numbers a little bit, do to gear change.
Intuitively I would say "yes", 1 3/4 would be a benefit. I ran some scenarios using Engine Analyzer Pro to see what the sim would spit out. I used this sim to model my 383 build and the predicted results were spot on with my actual experience several months later. Others have had the same experience with this tool.
For all simulations I used a 15% driveline loss factor.
Sim 1: Currrent engine...1 5/8 headers, cam, stock LT1 heads
Peak HP: 332
Peak Tq: 349
Avg HP: 247
Avg Tq: 307
Sim 2: Switch to 1 3/4 headers
Peak HP: 331
Peak Tq: 343
Avg HP: 245
Avg Tq: 305
Sim 3: Switch to 1 5/8 headers & AFR 195 Street Heads
Peak HP: 393
Peak Tq: 373
Avg HP: 269
Avg Tq: 326
Sim 4: Switch to 1 3/4 headers & AFR 195 Street Heads
Peak HP: 397
Peak Tq: 377
Avg HP: 268
Avg Tq: 324
You can see the initial sim is pretty close to what your actual results were. Keep in mind that I had to guess at some of the cam specs such as opening and closing, duration @ .200, etc.
What the results show are that the stock heads are a severe restriction (no surprise there) and that a switch to 1 3/4 headers will not gain you much if anything. Obviously there are a lot of other variables to model, but EA Pro is a pretty darn good tool. IMO the results are directionally correct even though they may not match what some would consider the logical answer.
So if you believe the sim, the real question boils down to hp/$ & tq/$...Is an increase of perhaps 10rwhp / 10rwtq worth $1000 (maybe net $250-$500 if you sell your 1 5/8 headers)? Only you can answer that question. If it was my money...I'd be totally focused on the cylinder heads.
