DIY tpi runner mod
Old Dec 27, 2009 | 05:28 AM
Cadmaro's Avatar
Cadmaro
Default DIY tpi runner mod
I started a strange little project a while back and never got around to finishin it. Im considering starting up on it again but thought id see if anyone thought it was worth the effort/ time. Idea is to cut the "middle" out of some runners and weld a flat plate in where the middle was to kinda "siamese" the stock runner all the way down makin a big oval runner instead of 2 little round ones. In my head it will have effectively shorter runners and more plenum volume which would make for more hp and a higher powerband. Think it will show any performance gains ? Will it be worth the 50 bucks in supplies to finish it?
Old Dec 27, 2009 | 08:58 AM
1985 Corvette's Avatar
1985 Corvette
Will be interesting to watch this homemade project. Keep us updated.
Old Dec 27, 2009 | 11:17 AM
cv67's Avatar
cv67
St. Jude Donor '05
Do it.
Old Dec 27, 2009 | 12:18 PM
floridamale's Avatar
floridamale
Do it.
Great idea to make a set of runners that should work well for almost no money. I will look into this mod myself.
Old Dec 27, 2009 | 01:06 PM
Cadmaro's Avatar
Cadmaro
Ok im convinced. Project is on. Probly be slow moving though. General consensus on tgo was it will work great with porting on the base plate and plenum so thats wat ill do.
Old Dec 27, 2009 | 01:30 PM
Davejs's Avatar
Davejs
Do you plan to mig or tig weld it? I have an extra stock TPI I could mess with if yours works good. Keep me posted on the results, the tach sould be the first indicator of how much extra it breathes.
If you really wanted to make a real bad A$$ intake cut the flanges off and get large oval tubes welded in place.
Old Dec 27, 2009 | 01:44 PM
steven mack's Avatar
steven mack
I know you want to use the parts you have.But I think you would be better off using a used set of SLP runners.If you buy them used that would keep the price down.Over at Third Gen. Org.they have siamesed the SLP runners base and plenum and gotten close to 400 horsepower and torque on a 350.
Old Dec 27, 2009 | 01:45 PM
Cadmaro's Avatar
Cadmaro
Local weld shop is gonna tig it for me. Only chargin 40 bucks for the strips of alum and the welding.
Old Dec 27, 2009 | 02:01 PM
Cadmaro's Avatar
Cadmaro
The reason im using these runners is becuase they were only ten bucks. And total cost for all mods will only be around 100 bucks. Which is considerably less than used slp runners. The price of the aftermarket tpi parts a absolutley rediculous so im determined to find a cheaper solution. And i cant imagine that much of a flow differents btw the slp and this setup. Maybe im wrong. But at least it will be cheap.
Old Dec 27, 2009 | 02:08 PM
steven mack
It will make for an interesting project.We will wait for the results.I agree the aftermarket stuff is pricey.
Old Dec 27, 2009 | 02:15 PM
Yorcci's Avatar
Yorcci
You mean like this?
Or are you going to siamese all the way to the bottom side holes also?
Old Dec 27, 2009 | 02:28 PM
pologreen1's Avatar
pologreen1
awesome Yorcci
Old Dec 27, 2009 | 02:39 PM
powerpigz-51's Avatar
powerpigz-51
I am very interested how this will work, I have been thinking of doing the same thing to mine. I have been looking for a cheap set of SLP's, some people ask more on Ebay than I can purchase a new set for. WS6 store sells them for 275 bucks. I even purchased some Aluma-Weld rods that allow you to braze aluminum with a Mapp gas or propane torch. I already have a Edelbrock ported base.
Old Dec 27, 2009 | 05:50 PM
Cadmaro's Avatar
Cadmaro
Yeah like the pics except all the way down and probly siamese about 1-2 inches into the base and hog everything out as much as possible. Where did u find the pics? Ive been lookin for pics of somethin like it finished for a couple weeks to no avail.
Old Dec 27, 2009 | 08:00 PM
rodj's Avatar
rodj
Several guys did it years ago.
Old Dec 28, 2009 | 02:14 PM
Davejs's Avatar
Davejs
That welding rod your talking about is JUNK! Neighbor used some of it on parts and it took about twice as long to reweld it and fix that mess.
Old Dec 28, 2009 | 03:18 PM
pologreen1's Avatar
pologreen1
it does not bond well or what?
I thought about trying some for small things to touch up, but never did.
To DIY tpi runner mod
Old Dec 28, 2009 | 10:05 PM
redrose's Avatar
redrose
ok for leaky beer cans and similar thin wall... castings/bigger stuff draw too much heat.
Old Dec 28, 2009 | 10:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
This was done many years ago when the TPI first came out. The runners, as said are thin so it will take the right guy to stich them back up but it can be done. Hey for $50 total Id think it would be hard to go backwards. Like seeing backyard stuff being done even though its easy to go buy aftermarket.
Old Dec 28, 2009 | 10:13 PM
powerpigz-51
I'll let ya know how it works....I plan on trying it out on some aluminum sheet first. Like all welding, brazing, and even soldering, it may take some practice to master the proper technique. Soldering is even difficult for most people if they have never done it before.
