Speed sensor problems? Maby?
Old Jan 3, 2010 | 11:31 AM
600RR's Avatar
600RR
Default Speed sensor problems? Maby?
Ok I have a BIG problem with my 92! About 3 weeks ago my break light on my dash came on I thought maby it was a switch for the e-brake so I checked that and it was ok so I didnt think nothing of it. Then about 2 days ago my speedo quit showing me how fast I was going ( reading 0 ) and the tranny felt like it was slipping in and out of gear ( starts doing it around 30 - 45 mph ). So now Im thanking its the speed sensor or maby somthing else. Has anyone ever had this issue? Are there any other sensors that could do this? Its the only means of transpertation other than my bike and its way to dam cold to ride this time of year so I need to fix it quick. Please help!!!
Old Jan 3, 2010 | 01:20 PM
engle1147's Avatar
engle1147
Radical weather exposure can make electronics/mechanical equipment act funky.
Check the car for stored trouble codes....could be more going on than you realize.
Potential tranny slip:
If this is an automatic - warming the engine/tranny up to temp then check the fluid level is always a good place to start.
VSS:
If you feel the speedo sensor (VSS) is at fault disconnect the electrical connector and remove it from the transmission then hook a volt meter up (use the lowest AC voltage setting) at the sensor's connections and spin the gear drive on the sensor if you get any voltage out of the sensor the sensor is most likely fine so look some where else for an issue.
If you have a AC frequency generator or access to one you can hook it up to where the speedo sensor (VSS) should connect and apply voltage back to the car which should trigger a false speedometer reading on the instrument cluster to help "divide an conquer" your speed reading issue. Most GM stealership service centers should have a 30 - 60HZ frequency generator on hand that they can test the speedo/cluster/circuits with.
Old Jan 4, 2010 | 12:09 AM
94vettelover2's Avatar
94vettelover2
Sounds like a speed sensor problem to me.Transmission is shifting funny because computer is not seeing mph/kph(movement).Check to see if an animal or debris damaged wiring or if theres any physical damage to area.I think a speed sensor is not too expensive.Keep us updated
Old Jan 4, 2010 | 07:15 PM
600RR's Avatar
600RR
I figured that it had to do with that. Would that explane why my dash goes in and out at times? I wont be able to have time to mess with it till next week. I just hope it dont hurt anything till I can get to it. Hell I bet I cant even find one here in town lol. If I got time Im gunna order it tomarrow at lunch. ( along with my u joints ). This thing is becomming a money pit
Old Jan 6, 2010 | 02:08 PM
pcolt94's Avatar
pcolt94
The brake fluid may be low and activating the sensor. The master need to be real full at least up to the line. Add some fluid if it looks slightly low.
Old Jan 6, 2010 | 02:42 PM
94vettelover2
You think your cold in georgiaTry freezer weather here
Old Jan 7, 2010 | 07:25 PM
600RR's Avatar
600RR
LOL I moved from Kansas for a reason
Old Jan 7, 2010 | 07:26 PM
600RR's Avatar
600RR
Was my secound thought but nope not the fluid
Old Jan 15, 2010 | 05:31 PM
600RR's Avatar
600RR
Ok I cant find this thing any ware. This is bs, everone I have called has told me the VSS for my car has been discontinued...... WTF do I do now?
Old Jan 18, 2010 | 01:39 PM
94vettelover2
Check the internet,corvette part suppliers,Chevrolet dealers,etc.You will be able to find one.Let us know how it turns out
To Speed sensor problems? Maby?
