'89 starting problem?
Old Jan 3, 2010 | 02:35 PM
jstewp's Avatar
jstewp
Default '89 starting problem?
My '89 convertible has an inconsistent starting pattern. The car fails to start and has to have starting fluid sprayed into the fuel induction system. I have cleaned the injectors, replaced plugs, distributor cap, rotor and air flow sensor. Any suggestions will be appreciated.
Old Jan 3, 2010 | 02:48 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does it run fine after you get it going with starter fluid ?
Have you ohm tested the injectors, cold and hot ?
Old Jan 3, 2010 | 03:00 PM
jstewp's Avatar
jstewp
I have not checked ohms of injectors, however, car runs good after the starting fluid gets it started.
Old Jan 3, 2010 | 03:06 PM
AGENT 86's Avatar
AGENT 86
Do you hear the fuel pump run for 2 seconds, when ignition is turned on ?
Old Jan 3, 2010 | 03:17 PM
jstewp's Avatar
jstewp
Yes, the fuel pump is new also.
Old Jan 3, 2010 | 03:22 PM
AGENT 86's Avatar
AGENT 86
What is the fuel pressure when ignition is turned on ?
Old Jan 3, 2010 | 03:33 PM
jstewp's Avatar
jstewp
Can you help me with testing info?
Old Jan 3, 2010 | 03:35 PM
AGENT 86's Avatar
AGENT 86
Do you have a pressure gauge that can mount to schrader valve ?
I would ohm test your injectors, in the mean time.
Old Jan 3, 2010 | 03:39 PM
jstewp's Avatar
jstewp
Thank you for the help, I will try to test these points.
Old Jan 3, 2010 | 03:44 PM
AGENT 86's Avatar
AGENT 86
Check out Jon's video on ohm testing.
http://forums.corvetteforum.com/c4-t...questions.html
Old Jan 3, 2010 | 03:58 PM
jstewp's Avatar
jstewp
Thank you
engle1147's Avatar
engle1147
Get a hold of Jon with FIC he'll size your applicaition up for ethenol compliant Bosch III injectors.
Old Jan 3, 2010 | 11:56 PM
94vettelover2's Avatar
94vettelover2
You may have a bad coolant temp sensor.If you have no access to scan tool to see what coolant temp computer is seeing just replace sensor as its cheap.Just make sure its for the computer.Does this year car have a cold start injector?Have you replaced fuel filter?Any codes stored in computer?You can use paperclip method to retrieve codes
To '89 starting problem?
