Fan relay's
Just wondering if the relay contacts are burning up or the coil is opening?
I guess there might be different manufactures of relays but have not gone down that road yet.
The sealed relay is a common NTE R51-1070-12, rated at 70A, versus the factory's 30-40A. Roy added a small diode across the switching portion to eliminate arcing which he states burns out the contacts on the Delcos. I see no reason why adding a diode wouldn't similarly help a stock relay.
The downside of the NTE relay (available and nearly any electronics store) is two larger lugs, part of the higher rating, which will not clip to the Corvette harness. I haven't found a plug, so four spade connectors are used. Roy epoxied a small mounting tab, with a hole to affix it in the stock place, with the stock hardware.
The banded end of the diode goes on the IGN switch side, the blue wire next to the red BAT feed in the early C4.
The upside is doing this once and that the NTE is totally sealed. I will make another one for my Corvette truck project.
Even if you have a later 'vette that drives the relays from the ECM, the diode will reduce the load on the ECM, so the diode across the coils is a good idea for both fan relays. (The stripe on the diode must go toward the + voltage).
Thank You, veterans!
Not sure about the "fan" relay off hand but most of the relays in these C4 relays already have an internal resistor across the coil to reduce the bounce/surge.
A small metal oxide varistor (MOV) can also be used to take the bounce/surge out of the relay's coil to reduce the burn effect of the bouncing contacts on the other end of the fan circuit that is being open/ closed. Hook the MOV up the same way polarity wise as Hot Rod Roy suggests.
opps should have been this
