Tech tip
Old Jan 20, 2010 | 01:28 PM
Millah's Avatar
Millah
Default Tech tip
What do you guys think of this tip?
https://www.corvetteforum.com/techti...=154&TopicID=2
Old Jan 20, 2010 | 01:34 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Interesting
Old Jan 20, 2010 | 01:47 PM
F0RMULA's Avatar
F0RMULA
interesting indeed.
can anyone confirm this?
if so, i'll go do it today.
Millah's Avatar
Millah
I thought so to. Might try it, But I dont want to over pressure my system and blow something out. I also wonder How this will affect your pressure regulator?
Old Jan 20, 2010 | 01:50 PM
RetiredSFC 97
I would be very hesitant to bypass a regulator that is there for regulation of fuel purposes.
engle1147's Avatar
engle1147
I would think that running a higher fuel rail pressure would only "show" a difference running at WOT. At different throttle positions other than WOT - I believe the computer would attempt to correct the enrichment by reducing the injector's "flow"
Old Jan 20, 2010 | 01:58 PM
Flame Red's Avatar
Flame Red
+1 on that. The computer can correct the fuel being dumped by the injectors up to 25% I believe. If it is seeing it run rich because more pressure is dumping in more fuel, it will compensate.
I have an adjustable pressure regulator, and I gave up playing with it and just set it to the stock 43 lbs. If you want to dump in more fuel you have to play with the ECM programming.
Old Jan 20, 2010 | 02:04 PM
Steve20's Avatar
Steve20
doen't make sense?
When the ECM is reprogramed, ie performance tuned, isn't it usually to lean out the factory setting?
This mod seems to richen it up instead
Steve
Old Jan 20, 2010 | 02:05 PM
TJM's Avatar
TJM
Sounds backwards?
I have just gone through the fuel process because of a issue with gas in my plenum, and the FSM says the vacuum line is to INCREASE fuel pressure with load?
So how can no vacuum on the same pump pressure do anything?
TJM
Old Jan 20, 2010 | 02:30 PM
86PACER's Avatar
86PACER
This tech tip is at least 7 years old. I remember doing it back in '02.
Old Jan 20, 2010 | 02:32 PM
F0RMULA's Avatar
F0RMULA
and whats the verdict?
Old Jan 20, 2010 | 02:45 PM
86PACER's Avatar
86PACER
I would see a slight MPG gain of at max 1 MPG when it was disconnected and capped off. I do remember testing with and without on the same stretch of freeway back to back under same driving conditions, speeds, etc. I would drive a certain amount of freeway miles using the trip meter, stop, pop the hood open, plug it back in, and drive back the same road and distance. I felt no noticeable difference in performance, certaintly no "serious" change in acceleration. My coolant temps where unaffected.
Old Jan 20, 2010 | 03:01 PM
Millah's Avatar
Millah
Sounds like it dont do much of anything?
Old Jan 20, 2010 | 03:12 PM
F0RMULA's Avatar
F0RMULA
if it bumps up the fuel pressure i would consider doing it.
does anybody know for sure? raises/lowers fp?
Old Jan 20, 2010 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Waste of time, IMHO.
Old Jan 20, 2010 | 03:27 PM
AGENT 86's Avatar
AGENT 86
It will raise you idle and cruise pressure to the same pressure you would see under WOT or high load. The ECM will adjust when in closed loop. It will not make it higher than the reg is set for.
Old Jan 20, 2010 | 03:28 PM
86PACER's Avatar
86PACER
I haven't bothered with it in years. In fact untill today I had totally forgotten about this.
To Tech tip
Old Jan 20, 2010 | 04:07 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
What Agent 86 said.
It's bogus. When you got to WOT (and have no vacuum in the intake) you end up w/the same fuel pressure anyway. You DON'T get better gas mileage. The display may show a better reading but that's b/c the ECM doesn't know about the mechanical change that's been made. If you did your gas mileage using long devision after a fill up, I'm sure that you'd find that this "mod" decreased your actual fuel milage.
Waste of time.
Old Jan 20, 2010 | 04:49 PM
JackDidley's Avatar
JackDidley
Its not going to do much for performance. The ECM constantly adjusts for rich or lean conditions (within certain limits). It wont affect the fuel regulator, the change is not huge.
Old Jan 20, 2010 | 04:58 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I heard about this years ago, 20? The theory was that the increase in pressure would change the injector spray by better atomizing the fuel. I have no idea if that's BS or not. I doubt the story's claim are accurate. I can't imagine you'd see that much difference unless the higher pressure was compensating for some other issue.
