U joint replacement
Old Jan 26, 2010 | 01:12 PM
Azriel's Avatar
Azriel
Default U joint replacement
Local chevy dealer told me the part would be $87.
ZIP tells me different.
Zip - Corvette
Would this be the right part? Or would I need something else? What do you recommend?
Old Jan 26, 2010 | 01:16 PM
JackDidley's Avatar
JackDidley
Just go to the local auto parts and get the lifetime guarantee one. Less than $20. The driveshaft joints almost never go bad anyway.
Old Jan 26, 2010 | 01:22 PM
Azriel's Avatar
Azriel
So:
Autozone
You might be brilliant.
I found this guy: http://www.ehow.com/video_2328177_in...tml?cp=1&pid=1
He has a video guide that seems good, but he's hammer happy.
Old Jan 26, 2010 | 01:30 PM
Azriel's Avatar
Azriel
He likes to talk about "love taps" a lot. Perhaps an indication of his relationship with his father?
Old Jan 26, 2010 | 01:34 PM
JackDidley's Avatar
JackDidley
Old Jan 26, 2010 | 01:37 PM
Azriel's Avatar
Azriel
"I'm gonna duck underneath the vehicle now, and install my driveshaft."
I bet you are, Nathan. I bet you are.
Old Jan 26, 2010 | 07:16 PM
j-wireman's Avatar
j-wireman
First of all, we've got aluminum drive shafts. They need to be pressed in, not hammered on. Secondly, my original u-joints came without zerk (grease) fittings. I think they're called "Lifetime" universals. I wanted the option of greasing them myself, so I bought new ones with zerk fittings. When I installed them, I found that I could not get a grease gun fitting onto the zerk fitting after the drive shaft was installed. No way. Obviously, I pulled it back out and replaced the unversals, AGAIN.
Just something I learned and thought I'd pass on.
Mike
'90 'vert
Old Jan 27, 2010 | 02:06 AM
Azriel's Avatar
Azriel
Mike
'90 'vert
Glad to know I won't be needing a hammer for the job. Makes my life a lot easier. So, this really should be a 30 minute job, eh?
Knowing my history with vehicles, I'll somehow turn it into a 5+ hour job.
Old Jan 27, 2010 | 09:55 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
$20 - $30 Harbor Freight Ball joint removal tool (looks like a big C-clamp)
A socket to fit the press, and either an electric or air impact wrench and you could do it in 30 min.
It will take 5 hours cause you will want to clean, this, that and the other thing.
Been there - done that. When I did my suspension rebuild I spent 1 1/2 weekends taking it all apart and 3 weeks of evenings and weekends cleaning it all up and putting in new bushings. Then 3 days to put it all back together.
Old Jan 27, 2010 | 08:53 PM
Joe C's Avatar
Joe C
- - been there done that too...
Old Jan 28, 2010 | 11:04 AM
engle1147's Avatar
engle1147
My 2 cents:
Most C4 vette owners - myself included, have discovered that all U joints are not created equal instead of bargin hunting for a part that won't last go with the "Spicer" brand of U joint for the best durability.
Old Jan 28, 2010 | 11:51 PM
Weav's Vet's Avatar
Weav's Vet
Originally Posted by engle1147
My 2 cents:
Old Jan 29, 2010 | 12:27 AM
John A. Marker's Avatar
John A. Marker
If you can find them in your area, Spicer is the way to go. They do not have zerk fittings which means that they can take more loading before breaking as compared to the hollow U-Joints with zerks. The last ones I bought also had a special coating on the caps to prevent the steel from reacting to the aluminum shaft.
To U joint replacement
