ac heater unit
Old Feb 4, 2010 | 09:51 AM
drayset1010's Avatar
drayset1010
Default ac heater unit
I just bought a 89 and fixed the engine and now to the other stuff. The heater unit is doing some funky stuff. Once in awhile it is fine and then all the light light up the temp indicator flashes all wierd. Is this the unit itself or could it be something simple
Old Feb 4, 2010 | 10:17 AM
drayset1010
I also have a flashing security light also. I just saw another furom that kinda said they could be linked any thoughts? also for 89 did they they have a remote for unlocking? and one more thing how do you remove the targs top with a torx tip?
Old Feb 4, 2010 | 10:19 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://forums.corvetteforum.com/1568603057-post3.html
Old Feb 4, 2010 | 10:36 AM
engle1147's Avatar
engle1147
The security light is supposed to flash...just not all the time.
No "factory" remote entry for '89.
use the torx bit....."lefty loosey righty tighty". Here's what I do:
Targa removal:
Slightly loosen all 4 bolts that hold the targa. Back out the "rear" torx bolts until they spin "free" then do the same for the "fronts". Remove the top.
Targa install:
Set the top in place. Start both the rear bolts then tighten both until the are about 1 full turn from tight. Start both bolts then tighten the front bolts until they tight. Go back and finish tightening the rear hardware.
Old Feb 12, 2010 | 06:14 PM
drayset1010
Ok I fixed it for the most part the only thing is it only goes up in heat. It will not let me decrees the temp. Did I miss a conection or is the unit done?
To ac heater unit
