1991 problems when running
Old Mar 1, 2010 | 09:19 AM
355flvette's Avatar
355flvette
Default 1991 problems when running
I just picked up a 1991. It will start and idle fine it just doesnt seem to go past 2200 rpm and dies. It has a new computer, new tps. Once it gets up to about 2200 it stumbles and then dies. It has about 43-38 lbs of fuel pressure. It was running like how my 87 did when the maf was bad. However this is a map car. Its not throwing any codes. So my next question is any advice? Also ive been reading up and where can you get a scanner and how do you ohm an injector? Thanks
Old Mar 1, 2010 | 10:16 AM
Y-ME's Avatar
Y-ME
Take a voltage tester, set it to ohms. When cold remove the clip off the injector and touch the two terminals with the tester. Ohms should be about 17ohms. If any injector is off by more than 2. ohms replace. Also test again when engine is hot.
Old Mar 1, 2010 | 10:20 AM
90EXPVette's Avatar
90EXPVette
I agree, sounds like mine before I replaced the injectors, besides running rich it ran pretty good until the computer couldn't compensate for them any longer and it wouldn't rev past 3K
Old Mar 1, 2010 | 01:05 PM
355flvette's Avatar
355flvette
i tested them all cold and they were all about 16.2 I couldnt keep it running long enough to get it to hot.
Old Mar 2, 2010 | 12:06 PM
shiyfire's Avatar
shiyfire
what about the coolant temp sensor?
Old Mar 3, 2010 | 12:28 PM
355flvette's Avatar
355flvette
put a new fuel filter in it, hot ohm tested the injectors and they stayed the same if not went up a little bit. Any other suggestions. Ill check the coolant temp sensor. It idles rough and smells rich. The fuel systems bled down about 20lbs in about 20 min. But stayed constant when running.
Old Mar 4, 2010 | 08:23 AM
90EXPVette's Avatar
90EXPVette
Can you drop the exhaust? I am wondering if it could be clogged cats...that's a long shot though.
Old Mar 4, 2010 | 10:49 AM
engle1147's Avatar
engle1147
I think this is worth a look....and it is easy. May want to have someone rev the engine while you check for increasingly positive exaust pressure out the tail pipes at higher RPMs
Old Apr 15, 2010 | 08:50 AM
90EXPVette's Avatar
90EXPVette
Did you ever find out what the problem was?
To 1991 problems when running
