Fuel Pump / Electrical Issues
Old Mar 11, 2010 | 07:48 AM
JAbraham03's Avatar
JAbraham03
Default Fuel Pump / Electrical Issues
I went to look at the firewall relays that another post commented on. I checked the first and it seems fine. The one closer to the firewall, the relay is there and fine, however there is not connector for it that I can find. What does that one go to? I am not getting power to my fuel pump and that would explain why if that is the pump relay. Thanks.
Old Mar 11, 2010 | 08:04 AM
rodj's Avatar
rodj
Year and trans always helps when asking questions
If two relays fitted, one is for the O/d
Did you try running 12V direct to the pump as outlined in the other thread to check the pump itself?
Have you checked pump fuse?
Is this a recent occurance as in did pump suddenly stop working?
Old Mar 11, 2010 | 08:33 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The rear one was fuel, from factory. Dig down and look some more, that harness can't be too far away.
Old Mar 11, 2010 | 09:10 AM
ant-knee470's Avatar
ant-knee470
Ant...
Old Mar 11, 2010 | 10:53 AM
JAbraham03's Avatar
JAbraham03
The car is an 84 with 4+3; The pump has not run since I got it. It does when I plug in 12V to it direct. The fuse for it is good. I am thinking that the harness missing is the cause of this. I will have to look further. The car will not run when I try to turn it on with 12V directly to the pump, I know fuel is getting to the injectors because I cracked a fitting there. I have already taken injectors out and inspected and replaced gaskets. I also know power is going to the probes on the injectors because I left one off to start it when I dumped fuel into the motor and it shot a lighting bolt across the engine. (oops) Is there a way to test the injector spray with the car off and just supplying power to them?
Old Mar 11, 2010 | 04:45 PM
rodj's Avatar
rodj
One side of the injector plug is live all the time when the key on .
You need a " noid " light to see if the injectors are being pulsed by the computer when cranking; the injector circuit goes to ground at the computer ,turning the injectors off and on
Old Mar 11, 2010 | 11:15 PM
JAbraham03's Avatar
JAbraham03
I just hotwired in a better ground. I am convinced, that if I can find it that I will find that they whole car has horrible grounds or broken wires from the previous owner.
Now it starts and injectors that sat for a year fan the spray great, however the car bangs and clanks...any thoughts?
Old Mar 12, 2010 | 02:29 AM
AGENT 86's Avatar
AGENT 86
The ECM must pulsate your TB's via sending a ground pulse, just like TPI. That being said, if you supply a constant ground to injectors, they will be sparying non stop, until you turn off the key !!
Old Mar 12, 2010 | 07:56 AM
JAbraham03's Avatar
JAbraham03
So you guess that the excess fuel is causing the noise?
I guess the ECM is the next place to look.
To Fuel Pump / Electrical Issues
