gas
Old Mar 19, 2010 | 04:28 AM
maverick1453's Avatar
maverick1453
Default gas
so how important is it that i put 91 super unleaded in my vette?
1993
i mean if i put the cheap stuff in and fill all 20 gallons with it, and use like the stp gas treatment thats like a buck at walmart to it.
will that clean it enough to be anywhere near comparable? or am i just bein way to cheap here
Old Mar 19, 2010 | 07:51 AM
bjankuski's Avatar
bjankuski
Put the correct gas in the car, octane boosters rarely work as well as advertised and they can leave deposits in the exhaust system that could cause some other problem.
Old Mar 19, 2010 | 08:45 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I agree. I don't like additives either.
I don't always use premium though. I have a 94 and often use regular. I do a lot of highway driving and for just commuting or traveling on the highway where there is only light loads the regular works fine.
I do notice a difference in performance. The premium runs better. I don't hear pinging with the regular, but it doesn't accelerate as good. I think the computer adjusts timing, etc so it runs but not as good.
Old Mar 19, 2010 | 08:55 AM
HlhnEast's Avatar
HlhnEast
Top Tier, Top Tier, Top Tier!!! I used to run nothing but Amoco, continued with BP til I found out they SUPPORTED Cap and Trade. I now buy Shell, Chevron, Exxon, maybe Texaco if the others arent around. The difference you save in a tankful, even over the long run, isnt worth the failure of engine/fuel system components
Old Mar 19, 2010 | 10:32 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Yea - another "What rating of gas do I use"
It says Premium reccomended, in the 90's the general had to make sure it would work with any grade. Lower rating gas, just watch how it runs. Don't try to get max power out of it.
With that said I've run all 3 grades in mine, 87, 89 & 93 (those are available here)
87 - It doesn't like it very much, mileage was bad as well
89 - runs OK mileage OK
93 - runs like a scalded ape, best gas mileage
Again this is MY car and my experience. I did my tests, you need to do yours.
As others stated a top tier gas will get you more cleaners in the gas. Try to stay away from 10% ethanol unless you've changed injectors.
Old Mar 19, 2010 | 10:46 AM
surfer92's Avatar
surfer92
1993
I have a 92 & 93 and run 87 when money is tight with 0 problems.
Also, gas is gas, only difference between different suppliers is the detergents added.
All gas for every supplier coming into FL goes into big tanks in Tampa and I have seen Shell, Mobil, etc.. tankers all getting gas from the same tank, they just add there detergents after filling up, also
the whole eastern seaboard is fed by 2 gas lines going from LA to GA.
Old Mar 19, 2010 | 10:58 AM
GKK's Avatar
GKK
You're being too Cheap.
Regular gas = Reduced engine performance and Fuel economy. The engine Ecm will Retard the timing to keep the engine from knocking and pinging.
So, you'll save a few dollars for every tankful but, it'll make up for it in less fuel mileage and poorer performance.
Old Mar 19, 2010 | 11:08 AM
GKK's Avatar
GKK
I'm sorry but, that's like saying, "Pizza is Pizza".
Yes, the Detergents are a Big part of what makes one brand better than the others.
Old Mar 19, 2010 | 12:03 PM
STL94LT1's Avatar
STL94LT1
I datalogged a friends 94 LT1 running 87 octane, it was under constant spark retard, even at idle. Will this damage your engine, probably not, but you will sacrifice performance.
Old Mar 19, 2010 | 12:11 PM
snoopdan's Avatar
snoopdan
I drag race my 86 pretty fequently, actually that's all its for these days. I run 89 octane and pull 8.11's at the 1/8th mile. Ok ok, it has a little nitrous help :P
But even without running nitrous, on pump gas vs. even 114 octane racing fuel, I saw no difference in my times. I was like "wtf, why did I just spend $50 for half a tank of gas?"
Old Mar 19, 2010 | 12:47 PM
aklim's Avatar
aklim
Hook up a scanner and see the knock counts to decide.
Old Mar 19, 2010 | 01:13 PM
surfer92's Avatar
surfer92
I was trying to educate him about gas.
and detergents are the ONLY difference.
In normal city driving, I saw no change in gas mileage using 87 over 91.
Old Mar 19, 2010 | 01:16 PM
aklim's Avatar
aklim
Detergents aside, how do you account for the different octane ratings?
Old Mar 19, 2010 | 01:33 PM
bjankuski's Avatar
bjankuski
This is the whole point, with normal driving you could get away with 87 octane gas since the VE of the engine is low with high manifold vacuum. If you decide to use the HP of the engine (and go WOT) then the low octane gas may knock and that will cause knock retard and reduced performance. The bottom line is if you own a vette and only plan to baby it you could run 87 octane gas, but then why own a vette, buy something better suited for gas mileage. If you plan to use the power a vette has use 92 octane gas and not octane boosters and 87 octane gas.
Old Mar 19, 2010 | 01:45 PM
surfer92's Avatar
surfer92
What???
Octane rating determines how long gas burns basically, normal driving does not need a high octane.
When you race or get on it, then yes a higher octane is better.
The OP asked about daily driving, so higher octane does little better.
Old Mar 19, 2010 | 02:22 PM
C4fan's Avatar
C4fan
St. Jude '10
A couple of years ago when the price got so high the wife and I did an experiment with our family car (Nissan Maxima). We knew the fuel mileage we were getting with the lower octane so we started using the higher octanes and the fuel mileage improved, even at normal driving. The bottom line for that experiment was that the higher octane was more efficient to run (miles/$ spent). So, if your on a budget and don't want to spend the big bucks of high octane you may still be better off spending the same money and just getting less but better gas. It wasn't rocket science for us to do this but we didn't depend on the fuel monitor on the dash for our results.
Old Mar 19, 2010 | 02:33 PM
aklim's Avatar
aklim
What???
What I meant was that if it was only the difference in detergents, how does one fuel get to be 87, the other 91 and yet 93?
I don't think so. I think it is a measurement of resistance to auto-ignition in gas engines. Higher octane, higher resistance to self ignition. Not sure what length of burn has to do with it.
OK
In my 91 Firebird, I would drive that around all days of the year including when there was snow. If there was no snow, I get on it a minimum of 3 or 4 times a day. That was my daily driver.
To gas
Old Mar 19, 2010 | 03:04 PM
Bill32's Avatar
Bill32
1993
Read your owners manual.
I've been runnin 89 for 5 years and at high altitude, no knock. And I get 30mpg on trips.
Old Mar 19, 2010 | 03:10 PM
engle1147's Avatar
engle1147
You're being too cheap.
10- 20 cents more a gallon for "super" shouldn't break the bank.
All those over the counter "gas treatments" at the store are pretty much the same thing...buy the cheapest one then add it with your next 93 fuel refill.
Old Mar 19, 2010 | 03:11 PM
aklim's Avatar
aklim
Did you verify it with the ECM's knock sensor? Just curious
