L98 dies
Old Mar 26, 2010 | 02:30 PM
organcory's Avatar
organcory
Default L98 dies
Its me again.... I have a 86 that when you take off from park that will die out on you if you dont give it enough gas, what could be causing this? The guy over at Mid America Motorworks stated that it could be the MAF sensor or the relays that go with it, mainly the relays as the MAF is hard to diagnose. Anyone had this problem?
Also are the parts from Mid America pretty good or is there a better place to get them?
Old Mar 26, 2010 | 03:47 PM
engle1147's Avatar
engle1147
How does the car idle in gear or in park/neutral?
Best solution:
Remove your TB and disasemble/remove the bottom housing off (the part with the IAC sensor threaded into it) the TB...clean the TB bores, IAC pintle and the internaly airpassages in IAC's housing....reassemble.
Assuming you haven't messed with the throttle stop screw - ensure that you TPS minimum voltage is between .40 - .62 vdc and do IAC reset proceedure.
OR
You can get some TB cleaner and try to spray the crap out of the TB while it is still mounted on the car and hope that gets it.
Parts: It depends on what parts you buy but you usually only get what you pay for. Most big catalog companies price match so shop around.
Old Mar 26, 2010 | 03:50 PM
organcory's Avatar
organcory
Alright here is my stupid moment, but WTF is TB?
Old Mar 26, 2010 | 03:53 PM
organcory's Avatar
organcory
disregard
Old Mar 26, 2010 | 04:12 PM
engle1147's Avatar
engle1147
My bad :o
TB = throttle body
IAC = Idle Air Control
Old Mar 26, 2010 | 06:08 PM
organcory's Avatar
organcory
jsut got the car off the trailer from NM, and it definitely has some hesitation. IT seems to happen when accelerating. If you rev it up it will eventually get past it.
Old Mar 26, 2010 | 07:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does the "Service Engine Soon" light up while driving ?
Do you know how to pull the trouble codes ?
Do you have a fuel pressure gauge ?
Old Mar 26, 2010 | 07:34 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Might be the Fuel filter, the MAF, the IAC,how old is the fuel in the car?
Old Mar 26, 2010 | 07:50 PM
organcory's Avatar
organcory
No
No
No
Old Mar 26, 2010 | 07:51 PM
organcory's Avatar
organcory
The fuel has probably been in there for a little while. It has been sitting in my moms garage in NM for a while which is also a very dusty place.
Old Mar 27, 2010 | 10:46 AM
organcory's Avatar
organcory
OK, here is the latest update. AS you all know I got the car off the trailer yesterday, and brought it home with it hesitating and acting like it was out of gas, which leads me to believe it was the fuel filter. The car had been on the trailer,backed in with its butt down, which meant all the gas headed back to the back, so we had to push it a little on the trailer to get it straight and then it started for a few minutes. We had to push it off the trailer the rest of the way to get it started again. I drove it home and parked it in my driveway. Later in the evening I started it up and drove it into my garage. This morning I go out to start it and it will just turn over but it wont start up. I went and got some MAF cleaner and cleaned out the MAF real good and let it dry and put it back in, but that didnt help any. I am stuck and not sure what to do next. So long story short, it no workie....
Old Mar 27, 2010 | 11:07 AM
snoopdan's Avatar
snoopdan
you could replace the relay for the maf, it's fairly cheap to replace and easy to get to, it sits right behind the battery. But honestly it sounds like you have a bad MAF. My 86 didn't throw codes and it was still doing exactly what yours is doing. First I replaced my MAF relay then just went ahead and replaced the MAF and bingo, no more problems!
Old Mar 27, 2010 | 11:18 AM
organcory's Avatar
organcory
Do the MAFs go bad fairly easy? The reason i ask is that my mom was driving this car 2 weeks ago, but did report some hesitation until you sped up and that it would die out.
Old Mar 27, 2010 | 12:33 PM
engle1147's Avatar
engle1147
Do the stuff in post #7 first.
Check for stored trouble codes (do a search here on the forum) This is very important...doing this will minimize your guess work.
Get a fuel pressure gauge that will screw onto the fuel rail. Do some pressure checks.
If no stored trouble codes:
If you don't know how old all the gas in the tank is you might want to pump that out and try to partially drain the fuel lines/rails by replacing the inline fuel filter. Refill it with fresh gas.
Old Mar 27, 2010 | 12:43 PM
organcory's Avatar
organcory
Ok, I will have to run to the parts store and pick up a fuel pressure gauge and a code reader. Should I go ahead and replace the fuel filter as well? What fuel pressure should I be getting?
Old Mar 27, 2010 | 04:14 PM
organcory's Avatar
organcory
Ok, I have Picked up a code reader and looks like it is getting a code 32.
Old Mar 27, 2010 | 05:33 PM
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/corvette86/Code%2032.pdf
Return the code reader, all you need is a paper clip or a piece of wire.
http://members.shaw.ca/corvette86/No...it%20Check.pdf
To L98 dies
Old Mar 27, 2010 | 05:45 PM
organcory's Avatar
organcory
The car will not start or run, So I am not sure what I need to do. This is the wierdest thing.
Old Mar 28, 2010 | 10:26 AM
AGENT 86's Avatar
AGENT 86
Fuel pressure test would be a good place to start.
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old Mar 28, 2010 | 04:42 PM
organcory's Avatar
organcory
so I guess I need to find the fuel pressure port, hook up the gauge and then turn the ignition to on? Where exactly is the pressure port, was that diagram underneath the car?
