c4 383/blower build
Apr 7, 2010 | 01:13 PM
Apr 7, 2010 | 01:19 PM
lol, can some tell me the easy way to bypass the ecm so the fuel pump will work. or do i just have to re wire it?
Apr 7, 2010 | 01:28 PM
St. Jude Donor '05
No answer on the electonics from here..
Your stock FP regulated will be around 43?! lbs
Your hollley doesnt need more than 6-7
Apr 7, 2010 | 01:29 PM
Apr 7, 2010 | 02:11 PM
ok i re wired it. works fine.
Apr 9, 2010 | 04:15 PM
well spent most of the day pulling the harmonic balancer because it was hit the frame. just had to grind a little off of the frame. drove around the block run real lean according to my air to fuel gauge. test and tune time!
ill get the hood on this weekend
Apr 10, 2010 | 01:03 AM
Apr 11, 2010 | 10:58 AM
So to sum up some issues I ran into for guys swapping out engines. Large harmonic balancers can hit the frame, If you are gona use the oem pump its easier to use a new relay with a new ignition source! and a new relay/switch for the fans.
Apr 11, 2010 | 11:00 AM
Apr 12, 2010 | 12:02 AM
that thing looks ****ing incredible. are you going to cut a hole in your hood?
Apr 12, 2010 | 09:23 AM
Quote:
Originally Posted by
Pwnage1337
thanx, and yezer
Apr 12, 2010 | 10:15 AM
St. Jude Donor '05
NOw wash your window and clean the fingerprints off teh bird catcher
We want vids when its tuned.
Apr 12, 2010 | 10:19 AM
Apr 12, 2010 | 10:22 AM
niiiice
does it work with an automatic trans ? if yes, where goes the tv cable ?
can it be used with fuel injected engines ?
Apr 12, 2010 | 10:49 AM
yes with auto you can see the cable in post 28. and yea you could use a FI
Apr 12, 2010 | 11:09 AM
lucster
did you ugrade the tranny ? or stock ?
Apr 12, 2010 | 11:47 AM
cuisinartvette
definitely want to see a video of massive burnouts lol
Apr 12, 2010 | 08:25 PM
stock r4 and yes im gona upgrade soon as i can. I will shoot some video this weekend
Apr 13, 2010 | 08:17 PM
well the 700 r4 did last as long as i thought it would! 3 days of abuse. well 1st gear still works
Ill get it back next week with a 2k stall
Apr 13, 2010 | 10:46 PM
lucster
all the way street. hoods the last step. ill post pics
Streetable ? If so bring it to Rosa's ! We can do a cacklefest !
