Weatherstrip Installed
Old Apr 9, 2010 | 11:38 PM
Bucs34's Avatar
Bucs34
Joshwilson - did your hatch leak at all?
Old Apr 10, 2010 | 11:25 AM
HlhnEast's Avatar
HlhnEast
Unless you tack it in the corners, your car will leak there with heavy rain unless you have the aftermarket drains to keep water from puddling. My car was hanging out a little bit and rainwater was pouring off the roof onto my hatch. I checked afterwards and all was fine. Do like I suggested, especially while the gaskets are new and havent shrunk. You may get away with no WS adhesive with OEM gaskets but I have never seen an aftermarket gasket that was a perfect match.
Good Luck with it!
Old Apr 10, 2010 | 08:58 PM
NitroNutt's Avatar
NitroNutt
Originally Posted by kenmohr
This is what it looks like when installed. The miters are cut wrong and it is too short to reach the outter corner.
This after filling a 1 inch gap because the miter was cut wrong. I did color this so it is not as noticeable but it still looks like s__t.
Use superglue next time. Works great.
Old Apr 16, 2010 | 09:57 AM
Bucs34's Avatar
Bucs34
Well...I have good news and bad news. I got the hatch, rear roof, and front of roof pieces installed. Let it set for a few days and then hit it with a hose test. The good part is that all the peices I installed didnt leak! the bad is that there is a pretty steady drip coming from about halfway across the top of the passenger window. Any ideas what could cause this? The weatherstrip on the targa looks good so Im wondering if the water could be getting in somewhere else and just dripping in there.
Old Apr 21, 2010 | 08:59 PM
Bucs34's Avatar
Bucs34
any ideas?
Old Apr 22, 2010 | 07:23 PM
navyndi2's Avatar
navyndi2
I'd try siting in the car while someone else hoses it down, be alot easyer to pinpoint the leak.
Old Apr 23, 2010 | 01:44 PM
Bucs34's Avatar
Bucs34
I did just that the other day. The water was dripping in pretty steadily at the middle of the pass. side window. All the seals over there look to be in good shape to me so Im not sure how its getting in. It almost looks like its coming from over the top of the window but it leaked even when we just simulated rain with the hose, no direct spray. Im confused?
Old Apr 24, 2010 | 05:29 AM
kenmohr's Avatar
kenmohr
Tape over the seams with masking tape. Glass to weatherstrip , weatherstrip to roof etc until leak stops. That is the leak.
