optispark?
Old Apr 12, 2010 | 06:45 PM
F.G.'s Avatar
F.G.
Default optispark?
Well, I own a 1992 Corvette auto with 90,000 miles on it. At stoplights in drive, after its warmed up, it would stumble a bit ever since I got it. I figured it wasn't normal but my dad's yukon with 175,000 miles has done it for years so didnt worry too much about it. But today I got caught in a light rain, the road wasnt really wet, it was just a very light rain. My car all of a sudden started to miss. I parked it and turned it off. turned it back on and ran fine (by this time the rain had stopped). Then if I would get in and out of the gas it would sputter or miss or something. When I was getting home (sun shining) the car acted normal. The car also threw no service engine light or anything. The only time this has happened before was about a month ago, When it was extremely windy and I was going up a steep mountain road. Any help will be appreciated
Old Apr 12, 2010 | 07:33 PM
F.G.'s Avatar
F.G.
ttt
Old Apr 12, 2010 | 07:34 PM
Bill32's Avatar
Bill32
You'll have to pull the codes for the opti.
They can also be messed up and take months to throw a code and lite the service eng. light.
If the plug wires are old, they can cause these problems, moisture can inhance these problems.
Start it up in a dark garage at night and look for arching especially where the coil wire goes from the opti, under the waterpump, to the coil.
Old Apr 12, 2010 | 08:04 PM
F.G.'s Avatar
F.G.
Thanks. will do. how do i pull the codes?
Old Apr 12, 2010 | 10:27 PM
aboatguy's Avatar
aboatguy
A paper clip and the following threads should help you out
http://forums.corvetteforum.com/c4-t...-retrieve.html
http://forums.corvetteforum.com/c4-t...n-96-cars.html
Old Apr 12, 2010 | 11:15 PM
pcolt94's Avatar
pcolt94
Several things can cause your problem. But if the cap of the opti is going bad it is not going to throw a code because spark is not monitored. Low and high resolution pulses are monitored and there's a code for them.
The opti could very well act up with several different symptoms and never throw a code. If after checking several different items and all look good, if you really feel it's an opti problem replacement if the best way to find out. I would look for any sparking wires that could cause problems similar to a opti.
To optispark?
