Tire PSI question
Apr 13, 2010 | 09:32 PM
Tire PSI question
I am running 30-psi have been for years, but the plaque on the door says 35psi....
Is that PSI what you guys are using?
Apr 13, 2010 | 09:40 PM
30. Rides pretty hard at 35.
Apr 13, 2010 | 09:50 PM
Cruise-In X Veteran
St. Jude Donor '09
I had slow leak issues with the corrosion on the wheel lip so for the past 2 years I made the mistake of running 38-40#. Now the tires are worn in the center. I fixed the slow leaks and now keep them @ 33#. The ride is still a bit stiff so I might drop to 30#.
Apr 13, 2010 | 11:00 PM
35 for me at 30 it feels like driving on oatmeal smooth but mushy. Even worse if you end up hitting a pot hole by accident it gets you painfully close to a rim strike. Pot holes are a New Englamd fact of life.
Apr 14, 2010 | 10:49 AM
I try to keep'em right @ 32 but have had no "strange" wear issues above 30 psi.
Apr 14, 2010 | 10:54 AM
I've been running 36psi for over six years and have mileage of 19,000-20,000 miles a year with no ill effects.
Apr 14, 2010 | 11:01 AM
Thanks guys, I may try bumping them up to 32-psi,, I have no wear issues, just spin issues when I get on it.
35psi gives me no traction at all, but I will try 32psi
Apr 14, 2010 | 11:22 AM
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I run my summitos at:
32 - street
34 - track
Apr 14, 2010 | 11:49 AM
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I run 34 front and 32 rear for street driving. On the track when I have to use my street tires its 36 front 34 rear hot and in the rain on track I run them at 42 front 40 rear to open the treads up a bit.
Apr 14, 2010 | 12:29 PM
Apr 15, 2010 | 06:52 AM
Cruise-In II Veteran
For handling on the highway I like 35psi around; at the strip 30-32 out back works best for hook.
