Engine One Side Hot, One Side Cold, Runs Like Crap
Old Jun 19, 2010 | 08:17 AM
  #101
My1st's Avatar
My1st
To check D15 & 16 I used D1 for ground and probed D15 & 16
Old Jun 19, 2010 | 08:34 AM
  #102
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by AGENT 86
How you ohmed D15 and D16, from ECM connector to injector connector ?
Sorry, that should have read, "have you" and not "how you"
You need to pull all the injector connectors off, before you ohm test between connectors and D15 and D16. Running a wire from D15/16, to the engine bay, will make it easier.
I'm heading off to my 6:12 tee time, I'll check back in 5 hours.
Old Jun 19, 2010 | 10:30 AM
  #103
My1st's Avatar
My1st
Good luck with your round of golf Dan.
I put her up on jack stands to check the grounds at G104 and found two possibly three wires that have the casing burnt off? and very rusted.
Going to remove the nut and pull the harness up through the engine compartment and try to trace their origin to replace the wires. If unable to find their origin I’ll splice and solder new wires in as far back as I can get. I’ll post back results as soon as I get it done
Old Jun 19, 2010 | 02:35 PM
  #104
My1st's Avatar
My1st
Repaired two ground wires but could only replace about six inches of wire. Plugged the harnesses back into the ECM without all the blue wires, hooked up the battery turned the key and it runs the same as before, didn’t change a thing.
I’m not finding a harness connection in the engine compartment for either bank of injectors. It looks like the injector wires go directly into the firewall?
Old Jun 20, 2010 | 08:15 AM
  #105
AGENT 86's Avatar
AGENT 86
I did not say harness connector, your going to measure from injector connectors to ECM connector(B15, B16). Be sure all 8 injector connectors are unplugged from injectors.
As for repairing the grounds, that was not going to change the "cold one side" problem, that was to clean up the PO's mess and not supply grounds to things that should get ground from the ECM.
I think your problem is the connection between ECM and one bank of injectors.
According to my FSM schematics, D15 and D16 are common inside the ECM.
If you find continuity between the 2 ends of harness on both banks, wiggle the harness while testing, to see if there is an intermittent open. If there was to be one, I would think it would be between the splice to 4 wires and the ECM. The splice is likely at the start of rectangular loom.
Old Jun 20, 2010 | 09:10 AM
  #106
My1st's Avatar
My1st
Just went out and checked each injector connectors. Ran a wire from D15 the driver’s bank and the needle on the ohm meter went to 0 on each connector. Did the same for D16 to the passenger side and got the same results. Wiggling the wires had no effect on the readings.
Old Jun 20, 2010 | 09:51 AM
  #107
My1st's Avatar
My1st
Forgot to mention I checked to see if one side was still cold when I started the car yesterday and both sides seemed to be equally warm.
After thinking about how it was running it seemed to be more fuel related sucking a lot of air when I put the gas to it. (It was also very hard to start). I just put my pressure tester on it and have 0 pressure and can not here the pump come on when I turn the key. I also turned it over and watched the gage and still no pressure. Also when I last scanned it came up with a lean condition. I guess it's time for a new fuel pump?
Old Jun 20, 2010 | 10:04 AM
  #108
walter schweigert's Avatar
walter schweigert
Is there a relay for the fuel pump that could also be checked?
Old Jun 20, 2010 | 10:18 AM
  #109
My1st's Avatar
My1st
There is a relay but how would you check it?
Old Jun 20, 2010 | 10:27 AM
  #110
My1st's Avatar
My1st
I forgot the ECM wasn’t hooked up so the pump is working but when I turn the key on the pump comes on and jumps to about 48lbs and within 30 seconds it drops to 15lbs what causes that? I replaced the regulator a couple months ago.
Old Jun 20, 2010 | 10:51 AM
  #111
walter schweigert
Just guessing: One or more leaky injectors, leaky FPR (fuel press reg.), and then there is some sort of a potential issue with a pressure compensator or something like that on the output side of the fuel pump which I have read sometimes leaks down pressure.
In my vehicle's case it was leaky injectors causing a prolonged hot crank.
One thing is for sure, it should not leak down that far that fast. Not sure whether it would cause just one bank of injectors to not work properly. Seems it would affect all of them.
Old Jun 20, 2010 | 12:49 PM
  #112
AGENT 86's Avatar
AGENT 86
So it's not cold on one side, that's good news, too bad it wasn't checked before ohming the injector harness.
Follow the steps in this link, to isolate where the pressure loss is. Mine was the pulsator, above fuel pump.
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Jun 21, 2010 | 06:33 PM
  #113
My1st's Avatar
My1st
Thanks Agent 86, I thought the test pinching off the inlet and return lines would be easy to do but Nooooooo you can’t get at the flexible hoses to pinch them off without draining the coolant and removing the lower radiator hose. Oh well! Have to do what you have to do just not for a few more days.
Old Jun 21, 2010 | 08:45 PM
  #114
94vettelover2's Avatar
94vettelover2
Hey keith.Been very busy lately but sounds to me like your computer is bad & may have been damaged from the PO wiring patches.You checked the harness from the injectors to the computer from what it sounds like.Did you switch all 4 injectors over to the other side.I was taught that one bad injector on one side can cause all the injectors on that side to not work(old GM saying).Make sure no matter what if it is the computer you get that wiring fixed properly so you don't possibly short out or ruin the next computer.It sure helps when people have that FSM to go by.Good job Agent 86
Old Jun 22, 2010 | 10:07 AM
  #115
AGENT 86's Avatar
AGENT 86
Pinch lines at fuel tank. Pull the fuel door and rubber boot and you will have access to the rubber lines. Be sure what ever you use is not sharp and 100% capable of stopping any flow.
Old Jun 22, 2010 | 05:06 PM
  #116
My1st's Avatar
My1st
Good thinking Dan sure beats the heck out of draining the coolant. Thanks!
Old Jun 24, 2010 | 07:58 PM
  #117
My1st's Avatar
My1st
It lost fuel pressure when pinching off both the supply and return lines (individually) at the tank so the FSM says it’s a leaking injector. The po said he replaced them and I found a UPS box containing some injector boxes with the name Bostech which are remanufactured so it doesn’t surprise me if one or more is leaking.
What size and brand should I get for a presumably (I have no history on this car) stock engine?
To Engine One Side Hot, One Side Cold, Runs Like Crap
Old Jun 24, 2010 | 10:37 PM
  #118
walter schweigert
That would be a question for Jon at www.fuelinjectorconnection.com.
There are original replacements, which is what I installed on mine, and then there are the Bosch III design, which may appear cosmetically different from the originals but have gotten rave reviews.
Old Jun 26, 2010 | 11:59 AM
  #119
My1st's Avatar
My1st
Went looking for a wet plug this morning but didn’t find any. I energized the fuel pump a dozen times and pulled all four driver’s side plugs and did the same for the passenger side but no wet plugs.
Wondering now if I was able to pinch off the feed and return hoses good enough and the drop in pressure is still pump/sending unit related?
I also pulled the vacuum line of the FPR and there was no fuel in it and being new it should be fine.
Old Jun 26, 2010 | 03:13 PM
  #120
My1st's Avatar
My1st
I picked up a Noid set and all eight injectors are getting a signal so it’s not running on four cylinders. Must be a fuel issue this time? thus the drop in pressure. As I mentioned I didn't find any wet plugs.
Is there any tests to check the fuel pump or should I just purchase a new sending unit and pump?
