Opti question
Old May 11, 2010 | 06:44 AM
Red-Lt1's Avatar
Red-Lt1
Originally Posted by pcolt94
You cannot look at all parts as having the same probability of failure. The ICM although connected to the coil and could have similar codes but the ICM fails much more than a coil. And also if you have read any amount of posts, the opti fails frequently as compared to the PCM. The PCM actually has a rather low failure rate and hardly ever hear of one actually being bad and correcting a problem. PCMs are actually very reliable unlike the ECMs in the earlier years. The opti fails left and right all the time.
I hope you have done some of the basics as suggested. The PMCs might be cheaper but harder to find. It bothered me you can't it to crap out in the driveway where you can take measurements. If you go for the PCM, I would hang on to my original one.
That is the frustrating part. My son is a service advisor at a dealership and gets the parts cheap. I will not be able to keep my old PCM unless I forfeit the core charge. He has gone through the flowcharts in the FSM. I still think that the new ICM is bad also. With the old ICM I get codes 36 & 42 when it stalls. With the new ICM I get a code 42 right after it starts up, and code 36 after it stalls.
Old May 11, 2010 | 08:55 PM
pcolt94's Avatar
pcolt94
I don't normally takes shots but.....
I would just then replace the ICM. It's under $100 and easy and fast to replace. If you are wrong it's not bad having a spare ICM for the future.
I would much rather take a shot on the ICM than give up a "working" PCM that is factory programmed. IMHO.
Most of the time the opti does not just kill the engine and then go again. They usually make poor running, bucking and other delightful things. But there is no absolute for the symptoms and anything can go.
It's just that from the law of averages I would put the PCM on the low end of the list. It's a tough choice when following the FSM, but there has to be a mix of written information with knowledge and experience.
Old May 12, 2010 | 06:23 AM
Red-Lt1's Avatar
Red-Lt1
My son is pretty good around cars but doesn't have experience with vettes. He is determined to figure out what is wrong without throwing parts at it. I have been letting him do it his way seeing as he is saving me a bunch of money. If it wasn't for him I would have to take it some place. I think that at some point I need to bite the bullet and take a shot at something and the ICM is probably the best place to start. I think that the Opti would be next although it cost more than a PCM. If it isn't the Opti a spare one would be better than a spare PCM.
Old May 12, 2010 | 09:50 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Ask your son if he can go old school - put an ocilliscope on it.
I forget which pin from the opti is the low pulse and high pulse but he should be able to see nice clear digital wave forms. Then check the inputs and outputs on the ICM.
Mine was crappings out doing the following:
Run car for 20 - 30 min (disable the fans let it get into the 250 range)
shut it down, wait 15 - 20 minutes let everything get good and heat soaked
Start the car and see what happens - mine would stumble, rpm all over the place, almost die
OBTW - my problem was resolved with a new ICM and coil. Opti didn't go out until the water pump went. I have a new problem, it appears related to the emissions canister with lots of pressure build up in the gas tank.
Old May 12, 2010 | 12:26 PM
Red-Lt1's Avatar
Red-Lt1
Sounds like it is worth a try. The coil has already been replaced. I was getting a code 16 as well as the 36 & 42 before I changed the coil and ICM. Now code 16 is gone. Thanks.
Old May 12, 2010 | 01:00 PM
MK 82's Avatar
MK 82
Default 95-96 Photo LT4
Does anyone have a photo of the tubing, etc under the left fuel rail cover? I took a thousand photos of my R & R but not under there.
If you have one with the cover off of a 95-96 LTX or a 96 LT4, it would be a great help. Specifically the routing of the vent tubing from the opti to the intake.
Eddie
Old May 12, 2010 | 02:58 PM
JAKE's Avatar
JAKE
Eddie
Eddie, I'll go out and take a photo now: 96 LT1
Jake
Old May 12, 2010 | 03:27 PM
JAKE's Avatar
JAKE
Eddie
Jake
Old May 22, 2010 | 06:31 PM
maranello_man's Avatar
maranello_man
Default Oscilloscope
Just thought I'd chime in on my progress or lack thereof with the same problem. I put an equivalent to a scope on my car to measure three things:
Signal from the PCM to the ICM
High res signal from distributor to PCM
Low res signal from distributor to PCM
Low res signal is always there. High res signal was intermittent. I found that if I wiggled the connector under the right plastic cover (over top of the injectors), I could make the high res signal come and go. I jumpered a wire around the connector and now it is steady.
I found that where the wires from the distributor went into the main wiring harness, they go through a piece of plastic that seemed to pinch them a bit. I think this caused a break in the wire. You might have your son put a scope on these signals at different points on the wire and see if he can make them go away, especially when wiggling the wires or the connector.
Still, when I try to start the car, I have no signal from the PCM to the ICM for about 6 seconds of cranking, and then the signal appears and the car will start and run well. I do still get the following codes:
C12
H36
H42
H62
H64
H42 (ignition control circuit shorted) makes me wonder if something else isn't wrong that keeps the signal from the PCM to the ICM from being there.
Onward through the fog.
Old May 24, 2010 | 06:41 AM
Red-Lt1's Avatar
Red-Lt1
Well after much testing and messing around with things I decided to go ahead and purchase a new PCM. I know some of you don't think that that is the problem, but I am at the point of needing to do something to get it back on the road. The PCM is cheaper and easier to replace than the opti. It has been ordered from GM and I should get it this week. I'm keeping my fingers crossed.
Old May 24, 2010 | 08:45 AM
mtwoolford's Avatar
mtwoolford
for what it's worth, an opti is nothing more or less than a distributor and like all distributors the rotor and rotor cap need occasional changing. Back in the day, with a "conventional" distributor (as in easily accessible), this is done on a routine basis. not so with the opti's. I suspect many opti "failures" are in fact rotor and rotor cap issues. what I noticed most when I changed out the opti on my engine was just how badly deteriorated the cap and rotor were.
Old May 24, 2010 | 10:52 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
C12
H36
H42
H62
H64
Mine is messing up again when hot. I know when I put on the dynaspark I put a new connector on the distributor side. Hmm Your experience has given me a place to start.
If you don't mind me asking - what did you use instead of an ocilliscope to look at the pulses?
Old May 24, 2010 | 01:06 PM
  #33
maranello_man
I used my laptop with a data acquisition (DAQ) board from National Instruments: http://sine.ni.com/nips/cds/view/p/lang/en/nid/14605.
It's about $280, but it has several analog inputs. I just spliced into the wires and cabled them inside the car to the DAQ board which connects with USB to my laptop.
Just as a side note, I've seen this problem on a few forums where the AC goes out at the same time. I have a code (can't remember the number) that my oil temperature sensor voltage is low. That means the car thinks the oil is very hot and shuts off the AC. I'm not sure if this is related or not, as I haven't tested it, but it coincides on my car with the distributor problem and seems to coincide in other cars as well. I also have a code 42 which is an ignition circuit shorted. this happens when the high resolution pulse from the opti is absent for a certain number of revolutions, I think it's 80.
