Adjustung Valves
Old Jun 22, 2010 | 12:57 PM
megtom2's Avatar
megtom2
Thanks. I'm starting to think this tired old l98 just doesn't like the 1.6 rockers.
Old Jun 22, 2010 | 02:36 PM
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
you know.. Im not sure about the F body.. but I would be checking the knock sensor and timing on this car.. what you are describing is preignition..pinging it sounds like a coffee can full of rocks being shaken.
Valve adjustment just isnt this hard. and if it isnt backfiring and missing they are probably very close.
Old Jun 22, 2010 | 03:38 PM
Killer408's Avatar
Killer408
Just a question, I may be missing something. Isn't the proper preload on the lifter 1 full turn? If you are only going 1/2 turn you are loosing that lift at the higher rpms.
Old Jun 22, 2010 | 04:46 PM
MK 82's Avatar
MK 82
You don't quite understand the system. More preload does not equal more lift.
Old Jun 22, 2010 | 07:02 PM
96GS#007's Avatar
96GS#007
Couple things...
If it's pinging, that is not the rocker arm adjustment. That is timing.
- Did you actually disconnect the ESC connector at the distributor and set the timing with a timing light or are you just winging it? Sounds like you're winging it. Even with too much advance, at idle the engine will sound fine and actually run quite smooth. Here's the danger....Too much advance and you could very well end up burning a valve.
- Do you know for a fact that the L98 springs have enough clearance to work with the stock cam and 1.6 rockers? With the added lift you risk experiencing coil bind. If the spring breaks and you drop a valve it won't be pretty.
Old Jun 22, 2010 | 07:41 PM
John A. Marker's Avatar
John A. Marker
with 96GS#007 concerning timing and springs. Double check these two areas.
Are you running the stock computer chip?
Old Jun 23, 2010 | 02:21 PM
Killer408's Avatar
Killer408
Maybe, but think about this. It is called preload for a reason. If do not have the proper preload on anything the end result will be incorrect.
This is also true with hydraulic lifters. If the preload is incorrect as load/rpm increases the lifter will absorb the preload adjustment that is not there thus loosing the lift and what some may be misconstrued as "pinging" may actually be rocker clatter because the lifter has absorbed the prelaod and is now too loose. Not always but at times. This can also go the other way on tight engines with high volume, high pressure pumps thus the need for anti pump up lifters so the oil pressure does not cause the lifter to push the valve open because of preload. I am a middle aged old fart that has been working on these engines for a while. Do not claim to know everything only what has worked for me and those I have done work for. Some times you just have to do things a little different.
Old Jun 23, 2010 | 04:25 PM
megtom2's Avatar
megtom2
Stock everything except for the rockers. I unplugged the est wire before I timed it.
Someone else has told me it sounds like coil bind. With 145k miles the springs could be weak since 1.6 is supposed to be fine with the stock cam and stock springs.
Thanks for all the replies. I will adjust them once again and maybe try my luck at replacing the springs.
I can now remove the valve covers in about 10 minutes so it isn't too difficult to go through them again.
Old Jun 23, 2010 | 11:26 PM
chileverde's Avatar
chileverde
Originally Posted by Weav's Vet
It's not a mess at all if you use a little common sense. Use cardboard like in this video will make no mess at all. Just make sure the cardboard is down in the head so the oil will drain back to the motor. Get the motor up to operating temp and have at it. When the lifter quits tapping turn 1/2 turn more and tighten it down. Works great!
Great vid there (and even greater sound! wow!)
i noticed you had the alternator and all brackets on the car with the serp belt in full operation.
is there enough clearance to remove the valve cover without pulling the alt or the rear bracket? i was thinking i was going to have to yank the alt to get the valve cover off...
rob
Old Jun 23, 2010 | 11:38 PM
Weav's Vet's Avatar
Weav's Vet
rob
Not enough room. You'll have to remove or pivot the alternator back on the back bolt to put the VC back on. No that bad and just takes a few minutes. Thanks for the compliment! That was with open headers. Won't be doing that again! Melted the d&*n shifter cable.
Old Jun 23, 2010 | 11:40 PM
chileverde's Avatar
chileverde
gotcha - but you did have room to adjust the rockers with alt and bracket in place?
Old Jun 23, 2010 | 11:42 PM
Weav's Vet's Avatar
Weav's Vet
Oh yeah, for sure.
Old Jun 23, 2010 | 11:49 PM
  #33
chileverde's Avatar
chileverde
cool - then it's cardboard and clatter for me... changing out the stockers for a set of comp's 1.5 pro-magnums.
Old Jun 27, 2010 | 05:19 AM
  #34
megtom2's Avatar
megtom2
OK I m back now with more info. I replaced the springs/seals on the driver's side of the engine and noticed that the roller tip is not the only thing touching. The self adjusting sides are hitting the top cover of the springs and getting nicked up pretty good especially on the exhaust rockers. Looks like I found what is causing the racket but what would cause the damage I am seeing? Pushrod length? From reading this forum and TGO I sure thought this would be a pretty straight forward swap but you live and learn.
Oh, the old springs were pretty worn out so changing them out was probably needed. Just replaced with stocked rated springs since I feel a little skiddish about going the mod route at this point. I am about ready to throw the 1.5 stamped back in and call it a day.
I'll try to get around to posting some pics later today and show what I am seeing.
Old Jun 27, 2010 | 09:22 AM
  #35
STL94LT1's Avatar
STL94LT1
It sounds like your self aligning tabs are hitting the spring retainers. If this is true, you need non self aligning rockers.
Old Jun 27, 2010 | 10:50 AM
  #36
ChrisLT1conv's Avatar
ChrisLT1conv
marked for later reference
Old Jun 27, 2010 | 10:57 AM
  #37
JAKE's Avatar
JAKE
You can come out cheaper by selecting different valve spring retainers. Retainers that will give you the needed clearance.
What you're seeing is a fairly common problem with SA rocker arms used in performance applications; guys on all the other Forums complain about this clearance problem.
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
To Adjustung Valves
Old Jun 27, 2010 | 11:33 AM
  #38
megtom2's Avatar
megtom2
Jake
I wish I had found that info before I started changing out springs yesterday. So I need something like these http://cgi.ebay.com/ebaymotors/CHROM...item5887a53905
or these
http://cgi.ebay.com/ebaymotors/sb-sb...item5d223cc95b
Old Jun 27, 2010 | 01:12 PM
  #39
65Z01's Avatar
65Z01
Cruise-In II Veteran
Did the stock heads have guide plates like the #113 in the Vette L98; if so did you remove them??
Did the stock motor come with self-aligning stamped steel rockers as do the Vette L98 with Al heads?
Old Jun 27, 2010 | 01:15 PM
  #40
megtom2's Avatar
megtom2
Default q
The L98 in the fbody uses self aligning rockers. The stamped ones that I removed were SA and no guides.
I guess this has gone from being an adjusting valve lash thread to being a "Before you go roller rocker this is what you need to know" thread. lol
