Horn(s)
Old Aug 1, 2010 | 12:20 AM
Azriel's Avatar
Azriel
Default Horn(s)
I think my horns have both died, and I'm trying to determine if this is the case, and what the best C.O.A. would be. I have my horns out, and I've connected the terminals on the horn to the terminals on a 6V lantern battery, to see if I get any sound. All I get is something that sounds vaguely like static. My question is, would the 6V be enough to make a drastic sound, or would I need something bigger? If my horns are both dead, what's the best (see also: cheapest) way to go about replacing them?
Old Aug 1, 2010 | 12:32 AM
dogfish246's Avatar
dogfish246
Why dont you use a volt meter and set it on DC... Connect the leads to the horn wires and have someone press the horn as you look for a volt reading?
Old Aug 1, 2010 | 12:37 AM
Azriel's Avatar
Azriel
I'm on a budget til the 6th, I don't currently have a voltmeter unfortunately. It's on my list of things I need. The only reason I need the horn is because my inspection was due in June, and I forget the horn has to work for that.
Old Aug 1, 2010 | 01:01 AM
GKK's Avatar
GKK
Just replace the horns with the Wolo brand "Maxi Sound" dual tone horns available at Pep Boys $35.
They're easy to install and sound great.
Old Aug 1, 2010 | 02:24 AM
Azriel's Avatar
Azriel
So, there's basically no way to get the exact same horn?
Old Aug 1, 2010 | 08:45 AM
WW7's Avatar
WW7
I have seen used Corvette horns on ebay every once in awhile, but no, not new.. The way I checked to see if it was the horns on my car was to take a test light( these are like $5.00 at Walmart) and put the ground clip on grounded metal , stick the tip into the wire from the horn, and have someone hit the horn. If it lights up its the horn , if it doesn't light its something else..WW
Old Aug 1, 2010 | 09:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Do you have a test light ?
Old Aug 1, 2010 | 11:40 AM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Use the test light from walmarts if it dont come on check the fuse or relay. My fuse was blown and the security lite in the center console wouldnt light up. I think the horns need 12v, 6v just wont work.
Old Aug 1, 2010 | 02:38 PM
M. Schumacher's Avatar
M. Schumacher
Six volts may not be enough.
If the coil in the horn has continuity (check ohms) then the diaphragm may be frozen. Remove the adjustment screw and squirt some penetrating oil in there. Then rap it a few times to free things up. Replace the screw and try it.
Old Aug 1, 2010 | 05:49 PM
Azriel's Avatar
Azriel
I put the multimeter on the contacts and it read about 1.5. I venture to say that's pretty well dead.
What setting do I need to test that the horns are getting power to the plugs?
Old Aug 1, 2010 | 06:27 PM
tblt44's Avatar
tblt44
the horns was the first things I replaced on my vette when I got it both were dead.
They are located too low and get water on them I think
Old Aug 1, 2010 | 07:31 PM
MotorCity_87_C4
1.5 ohms means there is continuity and at 12v it will draw 8 amps. Put your meter on DC volts 15v or something close scale and measure the voltage on the horn contact when pressing the horn button.
Old Aug 1, 2010 | 08:17 PM
94vettelover2's Avatar
94vettelover2
6 volts is not enough.Getting direct fit horns are much more expensive that aftermarket cut & splice horns-normally 3x or more expensive).Without tools get some wires & connect one wire to battery + & connect other end to 1 of the connector ends on the horn.Take another wire & connect to battery - & other end of wire to other terminal on horn.Horn should blow as long as battery isn't dead.If horn sounds/blows,that horn is fine.Without tools the other test to do is find horn relay & switch with another relay that is next to it & reconnect wires that go to horn from car wiring harness.Then press horn & see if it sounds.If does obvious you need a new relay.Also see if there is a horn fuse & see if the fuse is blown.Do these tests & let use know whatthe results are.May have broken horn contacts which means airbag has to come off if 1990 or newer-this is common problem as their plastic & get brittle over time then break.
Old Aug 2, 2010 | 02:06 PM
skybolt31's Avatar
skybolt31
I agree with Dogfish, but if you don't have a voltmeter or test light, instead of the lantern battery, whey don't you just use the battery in your car (or another car if it is easier to get to)? Mine were both dead, got some replacements at Autozone, spliced in the wires, now I have horns.
Old Aug 3, 2010 | 10:53 AM
1stvet87's Avatar
1stvet87
Azriel, i just went through this with my 87. I got one exact replacement from GM, the other had been superceded. The only real difference was the type of plug that came on the replacement horn. You would have to cut your plug off and wire in a different plug which comes with the horn. I got mine from Covert Buick there in Austin, from a guy by the name of Kent.
Old Aug 3, 2010 | 10:01 PM
mcm95403's Avatar
mcm95403
My favorite horn for those kids with the thump-thump thing going on:
http://www.youtube.com/watch?v=TiWNw0A1Ijg
Old Aug 3, 2010 | 11:30 PM
Azriel's Avatar
Azriel
I think those would fit nicely just in front of the wheel wells. What do you think?
Old Aug 4, 2010 | 04:54 AM
Azriel's Avatar
Azriel
Would anyone be interested in a step by step DIY guide for replacing a horn Relay? Because I've seen this picture posted a few times, showing where it's supposed to be. But that doesn't honestly help any.
Old Aug 5, 2010 | 09:04 AM
AGENT 86's Avatar
AGENT 86
Remove the instrument panel bezel and whatever is holding down the passeneger side of center bezel ( I don't have stock pad, so not sure what factory looks like).
Remove the center bezel and you will see the horn relay.
http://members.shaw.ca/agent86/Dash%...%20Removal.pdf
http://members.shaw.ca/agent86/Horn%20Electrical.pdf
To Horn(s)
