Knock sensor, would you run it with THIS setup?
90 l98 six speed vert
Here are my mods and future plan. Its a new engine installing it now.
388 Dart SHP splayed, forged pistons rods crank 9:1 comp
AFR 195s with 1.6 rr 7/16 stud
Comp 280xfi
http://www.compcams.com/Company/CC/c...?csid=209&sb=0
Superram ported with ported base to match, 30lbs injectors for now. (breakin period)
TPIS 58mm t/b
EM headers 1 3/4" 3" dual exhaust with xpipe to a set of stage one flowmaster.
Canton 7qt 250t with melling select 10%
MSD ignition/boost controller with the *** to adjust retard.
I am going to break it in this summer and then hopefully put on 15lbs of boost with a D1 supercharger with meth injection in the winter.
Thanks for taking the time to reply. Walt
Also a pic some pics for you guys
Mahle pistons are very grey in color. I found it strange.
Test fitting intake.
FWIW, mine are enabled...
383
lighweight crank
lightweight rods
AFR 195 Competition Eliminator heads
~11:1 compression
cam with 230/236 duration & .622/.624 lift
EM full length headers
bullet cats
lighweight flywheel
slightly north of 500hp at the crank
...and it passed the tail pipe emissions test
If your system is a mass air , get one for the early cars, if your using a map sensor, get one for a 90-91. But I'd make sre it was for your application....ie, corvette. You don't know what your chip is calibrated for, and if part of the calibration is the tuning of the knock sensor itself..
oh, by the way, push your tool box drawers in before it falls over..................
As far as the drawers go, I like to live on the edge.
...WW
