Adjustable fuel pressure regulator
Old Aug 6, 2010 | 05:59 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default Adjustable fuel pressure regulator
Anyone here run the Holley tpi afpr? I have an adjustable on my engine now but it is not acting as it should for some reason. The diaphragm is good but getting the pressure set is hit & miss. I am thinking of getting the Holley but would like some feedback. If not the Holley then what would be your choice?
Old Aug 6, 2010 | 06:06 AM
Weav's Vet's Avatar
Weav's Vet
I have the Holley. So far so good except the adjusting screw broke with me. I just replaced it and all seems ok. I had mentioned the Holley to Jon at FIC and he said that they have had a lot of problems with them. He didn't elaborate but you might want to get his input before buying one.
Old Aug 6, 2010 | 08:38 AM
cumbercr's Avatar
cumbercr
I used the TPiS regulator. I have not had any adjustment problems.
Old Aug 6, 2010 | 08:44 AM
jan-erik's Avatar
jan-erik
I have TPIS also and adjustments is just easy. I bought a spare diaphragm too.
Always had good experience with the TPIS people and service.
Old Aug 6, 2010 | 10:10 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have had the Holley for about 5 years, all is good and has to be the easily adjusted, from what I have seen.
Old Aug 6, 2010 | 10:38 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I have the Holley, and I had to file the edge of the body of it a little to fit my fuel rail. After that, it was set it and leave it. i checked it a few times after I installed it, but since it was always right on, I haven't touched it in maybe 5 years.
Just a word to the wise.........
DON'T PLAY WITH IT.
I was moving the center piece, and it fell out, and the spring with it. It was a bear to reinstall it with the spring shooting out of the hole till I got it right and pressed on the spring, pushed the pivot juuuuuust right, and then put it in a plastic bag till I installed it.
what a pita.
installed, it works as advertised.
Old Aug 6, 2010 | 11:40 AM
Midnight 85
Thanks Dan, that is exactly why I was looking at the Holley. The one I have has a small hex head screw and it is a real pita to adjust while the engine is running. I'm getting lazy in my old age.
coupeguy2001, thanks for the warning.
Old Aug 6, 2010 | 12:20 PM
scotth48's Avatar
scotth48
I have a Aeromotive AFR. Bought from JEGS. had problems with the first one, returned it fo another one and seems to be working fine. Looks nice too! '93 LT1.
Old Aug 6, 2010 | 03:48 PM
Midnight 85
Dan, I have another question, the only Holley regulator I can find for TPI lists Camaro & Firebird w/305. Am I missing another one for the 350 or would that one work? It's the one with a disc on the top for adjustments.
Old Aug 6, 2010 | 04:03 PM
engle1147's Avatar
engle1147
I run a BBK AFPR with no issues the thing is pretty straight forward just move your diaphram an spacer over.
NSV link removed
Old Aug 6, 2010 | 05:54 PM
Midnight 85
I'm afraid my diaphragm may be the problem in the adjustable I have now and by the time I buy a new diaphragm it's not too much more for a whole new unit.
Old Aug 6, 2010 | 07:53 PM
AGENT 86's Avatar
AGENT 86
That is the one
Old Aug 6, 2010 | 08:05 PM
383vett's Avatar
383vett
I run the Holley with the big disk on top and I think it's great. After a run and reviewing the datalog, if I want to tweak the afr throughout the rpm range, I'll just turn the **** instead of firing up the laptop and doing it through the computer. I have mine marked at 12:00 (on a clock). If I want to go a little richer, I'll move the **** to 12:30 or 1:00 if I need more. Moving it :30 will make a difference of .1 or .2 afr and it only takes a second. Helps to have a wideband.
Old Aug 6, 2010 | 08:06 PM
Midnight 85
Thanks!
To Adjustable fuel pressure regulator
