Transmission problem
Old Sep 4, 2010 | 12:09 PM
Calderone's Avatar
Calderone
Im not really convinced about it,i did a research long time ago , checked my converter and i found this : DGCF on my stock converter :
Then did a search for TC ID's and found this :
GM 4 digit code system... See the Code Tag on the converter!
1st digit is the APPLICATION
C = Early 700R4 w/27 spline # B15 series
D= '85-up 700R4 30 spline # B29 series
H=10 1/8" # B24 series
B24's use different codes 2nd Digit is the STALL range
G,H,K = 1200-1400 stall
E,F,L = 1611-1654 stall
B,C = 2000 stall
3rd digit is the type of Clutch & damper
1982-1995 most all codes interchanged
1996 up A,G,H,L CARBON Filled Clutch
N & P Woven Graphite Clutch
4th digit is the Cover type
C,D,F & G codes interchange
E code is a 6 Lug Diesel
What you think ?
then i upgraded to a 2400 stall converter
Check this :
http://www.bulkpart.com/Merchant2/me...e=4L60-700R4tc
Old Sep 5, 2010 | 10:31 AM
Crowhater's Avatar
Crowhater
I contacted pro-built and bought his street strip rebuild kit and the vigilante 9.5" 2500-2600 stall converter. With this conerter it is free to change the stall speed if I upgrade the motor later. I am aslo going to install a 40,000 trans cooler. The kit comes with the z-pac 18 or 14 clutch pack for 3-4 shift.
You guys have been great with your info and I feel I will have a real strong transmission when he is done.
Old Sep 5, 2010 | 07:39 PM
Calderone's Avatar
Calderone
Cool ! let us know the outcome !
