Propper torque spec for wheel (spindle) nut?
Old Sep 14, 2010 | 07:43 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by joshwilson3
So, you can't torque it too tight that would cause the bearing to wear? I had read somewhere of that. But I don't know alot about it.
No, the inner bearing race is sandwiched between the axle nut and spindle shoulder, there is no loading of the bearing as typical in a tapered bearing setup.
Old Sep 14, 2010 | 10:10 PM
sbrunkow's Avatar
sbrunkow
Navigator
How do I determine if the bearing is bad?
Old Sep 14, 2010 | 10:26 PM
samsonb's Avatar
samsonb
That sounds good. I had first tightened mine down with my impact wrench. But then figured I torqued it too much and backed it off. Then tightened it by hand and torqued it to 180 ft/lbs with a torque wrench.
Old Oct 13, 2010 | 08:59 PM
Trog's Avatar
Trog
I thought I had a rear bearing going out (loose when pulling at 12 & 6 when jacked up). Ordered new bearing and when I started to take it apart, axle nut was loose.... Just a slight hand tighten & now the bearing feels tight?
Anyone else have this happen? Not sure I really need to replace the bearing now?
Also, new bearing has a big pink note inside the box:
DO NOT USE IMPACT WRENCH AS THIS WILL DAMAGE THE BEARING
the other side says:
TORQUE TO 180 FT Pounds.
I'm going to re-torque the old bearing & then check it again after a couple hundred miles.
Old Oct 14, 2010 | 01:45 AM
samsonb's Avatar
samsonb
I wonder if the not to use an impact wrench is for the large spindle nut, or the 3 torx bolts? Shops tend to use an impact to tighten down the large spindle nut.
I've read that the spindle nut coming loose can be from a bad bearing. Though, it also can come loose if it isn't torqued down enough, or if the nut retainer isn't installed tightly.
