O ring installation advice
Old Nov 16, 2010 | 02:57 AM
Qiken's Avatar
Qiken
Default O ring installation advice
OK,Aside from taking deep breaths,what is the easiest way to insert the small rubber "0" ring onto the valve stem.
Old Nov 16, 2010 | 05:51 AM
corvette95's Avatar
corvette95
get a valve core puller tool and put in a new core. Total cost $5.00
Old Nov 16, 2010 | 08:02 AM
rodj's Avatar
rodj
He is talking about engine valves ; not tire valves.
Never had a problem ; just grease them and roll them on
Old Nov 16, 2010 | 08:10 AM
danno85's Avatar
danno85
Did you know that you have to compress the spring first? The o-ring goes on when you're installing the spring and valve locks. Compress the spring/retainer assembly, install the o-ring seal (use a small flat blade screwdriver to push it down into the second groove if needed), then install the valve locks/keepers. When you release the spring, the o-ring produces a seal around the inside bottom of the retainer.
Old Nov 16, 2010 | 09:55 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
They're flexible enough you can roll them down over the grooves, just be sure they are not twisted when you get them in place. With all respect to danno85 I would hesitate using a screwdriver, it could nick the ring causing early failure. Your thumb & forefinger are the only "tools" needed for this job, and a drop of oil of course.
Old Nov 16, 2010 | 10:39 AM
engle1147's Avatar
engle1147
I put my hat on backwards then slide them on.
Old Nov 16, 2010 | 10:52 AM
383vett's Avatar
383vett
Sometimes it's easier if you let her do it.
Old Nov 16, 2010 | 11:25 PM
Midnight 85
Old Nov 17, 2010 | 07:44 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did your seal kit come with the plastic sleeve that slides over stem and lock groove. Makes it easier to get them all the way to their groove without any damage from the lock groove.
Old Nov 17, 2010 | 08:41 AM
Qiken's Avatar
Qiken
I checked both packets and only had one sleeve,only lasted for 4 valves,as I'm doing cylinder by cylinder.used it for both seals and then cut it for use inserting the o rings.
Old Nov 17, 2010 | 11:38 AM
powerpigz-51's Avatar
powerpigz-51
I found a small piece of stiff plastic tubing the same diameter of the valve, cut it exactly the right length from the groove to the top of the valve stem (about 5/8") and tapered the bottom of it on my bench grinder. With the valve spring compressed, install o-ring, push tube down until flush with top of valve. works great, no guesswork. The tubing I used was hard plastic, like the type used for a water line. It wasn't PVC, more like hard nylon.
To O ring installation advice
