A/C issues
Cheers, Rick
http://forums.corvetteforum.com/c4-g...on-repair.html
Over 90% of the problems with the control head can be fixed very easily by doing what is described in the link!
This usually fixes the problem. One tip: After you remove the unit and it is on your bench (kitchen table, etc) spread a towel on the surface and place the head on it. Then start your dis-assembly. That keeps tiny screws and parts from rolling onto the floor and getting lost.
Let us know how you make out!
The first post is a good start for the button problem for the C68. However your fan problem is probably something else.
I would first check the fan control connector on the fan control module which is on top of the evaporator box on the right side under the hood. Look for any burnt or discolored wires. Check the pins for good contact and see if they look spread out. A bad connection can make the fan run full speed with no control.
