HELP Please!
Old Apr 14, 2002 | 04:28 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default HELP Please!
1996 LT-1 Automatic: This morning had a hard time starting, acted like it was hard to get fuel , then after starting it ran fine all day till a manifold leak, oil on drivers rear side. SO I took off manifold, replaced gaskets and put the right stuff on front and rear (and up onto the tabs of gasket, like you are supposed to), then after everything was said and done, refired it and a check guages light came on, no service engine soon light, and heard a rattling (front of motor, took off belt and restarted nothing changed) when in gear, and/or loaded with A/C then the motor loads up bad and dies. Changed MAF, and nothing, changed EGR (even though turned off by PCM, just checking for stuck open valve). Then with soapy spray water on manifold
to check for vacuum leaks, and nothing, no change etc. So, when you turn on A/C or put in gear it loads up and dies.
Also, Brand new OPTI, less than 1 month old. New wires, plugs.
Fuel Pressure with factory regulator and vacuum line disconnected 50psi (seems high).
[Modified by steve40th, 10:29 PM 4/13/2002]
Old Apr 14, 2002 | 04:41 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: HELP Please! (steve40th)
You may have false air, put a vacuum gauge on to see if all is ok there. First recheck all areas you had to touch to do the intake.
Old Apr 14, 2002 | 06:04 AM
steve40th's Avatar
steve40th
Default Re: HELP Please! (65Z01)
Checked all vaccum lines. When I took them off, such as fuel pressure regulator line, rpms went up as they normally do.
Vacuum is bad now, and it is gettin gworse. The engine has no power, sounds like timing/fuel mixture off.
Old Apr 14, 2002 | 02:45 PM
steve40th's Avatar
steve40th
ttt
To HELP Please!
