service engin light
Old Mar 7, 2011 | 11:43 PM
mike20o's Avatar
mike20o
Cruising
Default service engin light
my car is running great its an 86 and the service engin soon light is comming on every once in a while? does any one know what this is doing it for bceause i cant think of what is wrong with it could it be a glitch?
Old Mar 7, 2011 | 11:54 PM
jfb's Avatar
jfb
You can see what error codes are stored by turning the ign key to run (engine not running) and shorting between the top right two pins on the ALDL connector above the drivers right knee. The SES (service engine soon) light will flash a 12 (flash flashflash) three times and then flash the stored error codes. Write the codes down and either look them up in the GM service manual or post them here.
Old Mar 7, 2011 | 11:59 PM
mike20o's Avatar
mike20o
Cruising
k should i just go to a place where they can hook that connection up that is by my knee? or is their a way the car its self will display it
Old Mar 8, 2011 | 12:23 AM
jfb's Avatar
jfb
I just explained how you can retrieve the stored error codes all by yourself. Read my post again. You can also let a repair place use a scan tool to retrieve the stored error codes. Many places will do it free.
Old Mar 8, 2011 | 08:33 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://www.corvettephotographs.com/c4vettes/ecm.htm
http://members.shaw.ca/corvette86/No...it%20Check.pdf
Old Mar 8, 2011 | 09:29 AM
c4cruiser's Avatar
c4cruiser
If you have an AutoZone parts store near you, they will check the codes at no cost. Once you get them, post them here.
To service engin light
