How Much Hp
Old Mar 18, 2011 | 07:04 PM
illenema's Avatar
illenema
Default How Much Hp
Purchased a Lt-1. Going to overhaul it. What approx Crank Hp might I expect if the work is done correctly.
383 Stroke, head porting, Topend porting, hotcam.
Old Mar 18, 2011 | 07:07 PM
engle1147's Avatar
engle1147
~383hp
Old Mar 18, 2011 | 07:10 PM
STL94LT1's Avatar
STL94LT1
Rethink your camshaft choice.
Old Mar 18, 2011 | 07:12 PM
illenema's Avatar
illenema
Off the shelf suggestions please.
Old Mar 18, 2011 | 07:20 PM
STL94LT1's Avatar
STL94LT1
Are the heads being professionally ported? If so, have the porter suggest a camshaft to match the heads.
Old Mar 18, 2011 | 07:22 PM
cv67's Avatar
cv67
St. Jude Donor '05
Window shopping is always run....a start
http://www.crower.com/catalogsearch/result/?q=lt1
http://www.crower.com/chevy-lt1-hydr...-cam-7025.html
There are two with the same PN, guess the one with "S" at the end means solid. That would be fun.
http://www.crower.com/chevy-lt1-hydr...-cam-7024.html
Similar to hotcam touch bigger.
Did you have a stick or auto, gear?
To How Much Hp
