94 no start
Old Apr 13, 2011 | 12:08 AM
llesg's Avatar
llesg
Default 94 no start
A few months ago my car started backfiring.
I managed to get it home. I noticed some bits of catalytic converter at the tips.
I ordered some random technologies cats and put them in.
noticed some oil around the front of the motor and decided to change the timing cover gasket. got into that job and noticed the vacum line to the MSD Optispark had melted from the oil and oil was in my Opti again!!! About my fifth or sixth Opti/replace/clean/change.
I should have known the problem would be there!!!
So now I have changed ;
1) 2 Catalytic converters.
2) 3 oxygen sensors.
3) timing cover gasket,pan gasket
4) oil temp sensor
5) oil level sensor
6) water temp sensor
7) valve cover gaskets
8) fuel filter
9) oil and oil filter
10) coolant
11) sent opti to MSD to be cleaned out
So everything reassembled,turned the key and..................no start!!
Checked spark and it's good.
Looks like it's not getting fuel,it just cranks and cranks, no smoke,nothing
Any clues?????
I can't remember if I could hear the fuel pump before,I definatly don't hear one now.
Thanks in advance,Rick
Old Apr 13, 2011 | 09:39 AM
pcolt94's Avatar
pcolt94
Listen for the fuel pump, check fuel pressure.
Is it possible that you miss-aligned the shaft for the opti with the missing tooth. Just maybe in hast it is not aligned correctly.
Old Apr 13, 2011 | 09:52 PM
llesg's Avatar
llesg
I did'nt know that was possible.
I did'nt force it on , it seemed to go in easily.
I also changed the spark plugs and spark plug wires.
I shot some starting fluid in the intake and cranked it over this afternoon and nothing.
It did however kick backwards a little after I stopped cranking.
I checked the shrader valve for fuel and some shot out.
Pull the opti once again?????
I wish I had an LS motor!!!!!
Old Apr 14, 2011 | 12:27 PM
jfb's Avatar
jfb
Sounds like badly out of time spark. Since there isn't a timing mark to check timing with, one way to check is to rotate the engine until #1 cylinger is at top dead center and put a mark on the engine pully at 12 o'clock and then use your timing light to see if timing is close.
Old Apr 14, 2011 | 04:22 PM
pcolt94's Avatar
pcolt94
It happens more than you think. It can go on the wrong way Turn the engine so the shaft goes in at missing tooth at 12:00. Then set opti tooth for 12:00 also and install.
The opti bolts should only hold the opti in place. It should go on with a tink as it contacts the timing cover and be flush.
Since there is spark, opti, PCM, ICM and coil are all working. More than likely it out of time.
Install opti but don’t put water pump on. Make sure engine starts and runs first. Just put the MAF back on. You can stretch the wires and connect the temp sensor in the WP. Then when all is good finish the job.
Old Apr 22, 2011 | 09:24 PM
llesg's Avatar
llesg
Thanks everyone for the info, It seems like that is the right advice. I think I must have BAD-OPTI-KARMA!!! LOL I will have to check it when I get baci in town and I'll let Yall know the outcome. Rick
To 94 no start
