Solid axle and autocrossing?
Old May 24, 2011 | 10:39 PM
thetoy's Avatar
thetoy
Default Solid axle and autocrossing?
Has anyone out there that has a solid axle in there car ever tryed to autocross it? I just broke Another ujoint and it took out the batwing and the new spring again. I just replaced these and am getting tired of fixing this.
Old May 24, 2011 | 10:45 PM
87 vette 81 big girl's Avatar
I don't think so with anyone here on C4.
Everyone that autocross with a C4 uses the dana 44 or dana 36.
Solid Axle could work.
That will open up an entire can of worms here on C4 tech.
The old Penske Camaros' that ran the SCCA Trans Am circuits in the 1960's & 1970's all had solid/ live axle 12-bolt rear diffs.
Dan Gurney won a ton of races driving those Penske DZ 302 Z28 Camaros.
BR
Old May 24, 2011 | 11:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dont see why not
Im going to try it with my 67 'El, 12 bolt straight axle.
"Parking lot racing" isnt my thing but will do it once just to try.
Old May 24, 2011 | 11:30 PM
l98tpi's Avatar
l98tpi
Max G’s
holy s**t, you've got way too much power to autox, if you have the engine and power in your signature. Not saying you can't, I think you have too much power to manage as well as the shock you are placing on those suspension and driveline components. As far as a solid axle for autox, you would loose a lot more in handling and suspension load than you would gain in duarability. I have heard of guys on here using a solid axle for drag racing, which sounds like what that car is built for.
Old May 24, 2011 | 11:47 PM
thetoy's Avatar
thetoy
I do have the power that my signature states and have been autocrossing the car for the last 12 years with lots of power. It really does make the car harder to control but the look on people's face when I give the a ride while autocrossing is priceless. The rush I get when driving it makes it worth it. Since I added 150 Rwhp I only get about 4 events before something in the rear breaks . I have a local shop that thinks a 3 link system with a solid rear end would be the ticket to stop all the breakage. I'm concerned about if I don't like it you can't go back after it's been done.
Old May 25, 2011 | 12:05 AM
Check out "Big Red Camaro". Google it.
R.J. Gotlieb's very bad *** 1969 540ci BBC V8 Winston Cup Chassis Big Tires on all 4 corners.
Unique ford 9" inch rear setup.
Wishbone style rear axle location setup on coilover shocks.
He ran the Silver State Classic in 1989 and averaged 180+ MPH over 90 miles on that 2 lane highway closed off for the race yearly.
His top speed that year was over 223.0 MPH.
Finished the race in 20 or 22 minutes running flat out 90% driving.
RJ was only 18 years old at the time.
He was an Indy car driver from the Los Angelous, CA area.
A magazine reporter rode shotgun.
There is a vintage video clip from a helicopter TV reporter you can watch of RJ driving BIG RED at over 180 MPH , slowing down to 140 MPH through a mountain canyon sweeping "S" section in the highway over 2 miles long.
You can here RJ on the gas hard running flat out too.
Cool Stuff.
Watch that video clip............solid axle can & will work for high speed driving or auto crossing.
I am losing my independent rear C4 setup too.
Going Live axle setup too.
Street/ Strip setup for me here.
1957 Pontiac Rear.
I just have to be different & have the 57 Pontiac Rear already too.
BR
Old May 25, 2011 | 12:25 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Just curious, why a solid axle for auto-xing? Not a good choice for S2.
Busting u-joints could mean: too much HP, too much grip, hollow u-joints or too much body roll.
I've seen many C4's auto-X and breaking U-joints wasn't a big problem.
Old May 25, 2011 | 12:36 AM
I just checked out the profile of the C4 in question.......
He has a 461 CI sbc.
makes 650 rear wheel horsepower.
That means close to 800 HP at the flywheel.
Breaking U-joints is going to happen to him at those power levels.
I would not be able to keep my foot out of the gas likewise on a closed racetrack course too with his car/ engine.
BR
Old May 25, 2011 | 01:06 AM
Corvette0096's Avatar
Corvette0096
Here is a video of the car on the dyno. TJWONG was going for his 8 second ride and never got bucked off Yes the car makes 650 at the wheels.
http://www.youtube.com/watch?v=4BSLmJ-2Zt8
Old May 25, 2011 | 01:37 AM
JrRifleCoach
Whew! That's got to be a handful on a S2 course!
Old May 25, 2011 | 12:35 PM
mashinter's Avatar
mashinter
Make sure you check what class you'll be in with a solid axle (if that matters to you).
The 90s Camaros and Corvettes ran the same engine (LT1), same wheels and tires (275/40-17), and about the same weight (3300). On a rough course, the Camaros rear got a little looser than the Vettes; they would have to lift while the Vettes just kept the hammer down. On a smooth course, they were very close.
Old May 25, 2011 | 12:42 PM
cv67's Avatar
cv67
St. Jude Donor '05
if hes worried about brute strength then straight axle is the way to go.
Only 2 ujoints to worry about and no spindles etc that usually go.
Bet Moser could put together somethign stout for you.
Old May 25, 2011 | 01:26 PM
rklessdriver's Avatar
rklessdriver
SCCA Trans Am cars must run a live rear axel and they are some very good handling road racers.
All the cars I've see use a 3 link with a (very long) panhard bar, but the rules say 4 links and use of a watts link are also legal. I'm positive they are running cambered housings like the NASCAR road racing chassis use.
You can buy a new cambered 9" housing from Quick Performance or (if the width works out for you) a really good deal would be a used NASCAR housing from Muscle Motor Parts.
Oval track and NASCAR housings are full floaters and that is a really good idea for you to follow. Stripped drive hunbs and broken/bent axels do happen from various accidents or whatever and floater stuff is very cheap and easy to replace....
Will
Old May 25, 2011 | 08:16 PM
383vett's Avatar
383vett
I think my car will fall over if I tried to take a corner over 15 mph. I have a 3 link with a spool, skinnies, slicks, no swaybars, drag shocks, etc.
Old May 25, 2011 | 09:46 PM
Your Rear tires are doing the steering for You Willie off the line on a hard launch.
No Autocross tracks here in IL except for Rt 66 if they allow you on the NASCAR track there.
I have the drag race bug again thanks in large part to You Willie.
Your photos of Your 84 C4 launching over & over.
Old May 25, 2011 | 09:53 PM
383vett's Avatar
383vett
Thanks Brian.
Old May 25, 2011 | 10:23 PM
COPO's Avatar
COPO
four link is not really your friend for turning. but a triangled 4 link works nice. trans would have to be mounted solid and loose your tubs behind the seats.
To Solid axle and autocrossing?
