c4 performance
Old Jun 18, 2011 | 01:16 PM
Rob31's Avatar
Rob31
Originally Posted by muzikmanwi
I am beginning to think the catalytic convertors on these cars cause a lot of the performance problems people are experiencing.
Old Jun 18, 2011 | 01:18 PM
muzikmanwi's Avatar
muzikmanwi
Another great place to buy parts they have great pricing on Magnaflow just follow the directions for an email with your discounted price.
http://www.performancepeddler.com/default.asp
Old Jun 18, 2011 | 03:02 PM
quinten's Avatar
quinten
thanks for the help guys. I am anxious to get the car running and take it to some car shows this summer. as well as drive it (wisconsin has a short summer so i need all the time i can get)
Old Jun 18, 2011 | 04:50 PM
marcus410's Avatar
marcus410
Once I gutted my cat and did chambered muffler deletes on my 84(making much less hp than your car) it can now easily smoke`m up from a stand still.
Old Jun 18, 2011 | 06:27 PM
quinten's Avatar
quinten
I'll do the routine tune and see where than gets me. If I need injectors and a y pipe i'll tackle that after i know the basics are good to go. Thanks for the help. Much appreciated.
Old Jun 18, 2011 | 06:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
As you said basics are where to start. Timing, check the TPS positioning. things of that nature.
Some seem to run different than others all things being equal for some reason. Friends low mile 88 didnt seem like it had near the responsiveness as an 89 I had but mods were exactly the same, tuneup etc.
Old Jun 19, 2011 | 10:28 AM
Tony A.'s Avatar
Tony A.
How does one go about "gutting" the cat? Instructions please as I'm installing a cat-back system this week so while I'm down there....
Old Jun 19, 2011 | 10:54 AM
vader86's Avatar
vader86
Hammer + chisel or some other long metal rod.
Old Jun 19, 2011 | 02:18 PM
marcus410's Avatar
marcus410
Thats it,I used a long screw driver.Im assuming mine was still the original as it broke apart in less than two minutes.After I put everything back together I did notice at light throttle a whooshing,whistling sound....it was air blowing past the breather tube(which is located in the middle of the gut of the cat,once gutted its free to have lots of air pushed past it...like blowing on the top of a beer bottle).I took a bolt the same size and brazed it in the part of the tube that goes in the cat.May be Im just really picky but it did help.Being a musician maybe my ears are a little more keen to stupid things like this.I did a search and found nothing else on the matter.You might not even notice it.And depending on what mufflers your running the sound may never reach the end off the system,mine are chambered muffler deletes
Old Jun 19, 2011 | 02:42 PM
Tony A.'s Avatar
Tony A.
I just ordered the CORSA Sport Cat-Back exhaust for my 88. How do you think it will sound and perform with that exhaust and gutting it?
Do I need to take the cat off to do the gutting or can it be done on the car, connected to the front Y?
Old Jun 19, 2011 | 03:46 PM
vader86's Avatar
vader86
You need to take the cat off to gut it right. It'll be louder when you stand on it, and deeper.
These main cats on L98s cost you about 10hp on a stock car, so it does help the power to gut it.
Old Jun 20, 2011 | 08:06 PM
quinten's Avatar
quinten
Did the tune up today and it idles much better and pulls hard under full throttle. However from a dead stop when you give it full throttle it won't slip the tires kind of acts like it bogs out then pulls hard. Any ideas guys? The car is an auto not manual if it matters
Old Jun 20, 2011 | 08:22 PM
  #33
l98tpi's Avatar
l98tpi
Max G’s
Run the car for a while for a week or so and see if it changes. I would run the higher octane. My 91's call for premium only. Not sure about the 87. Regardless, the higher octane will have a more efficient burn and should keep the injectors cleaner. Also, run some fuel injector cleaner or octane booster through a tank once.
Old Jun 20, 2011 | 08:33 PM
  #34
Tony A.'s Avatar
Tony A.
I vote for SeaFoam as the injector cleaner....really smoothed my car out...
Old Jun 20, 2011 | 09:23 PM
  #35
quinten's Avatar
quinten
I'll give the car two tanks of injector cleaner and higher octane fuel without ethenol and see how it goes. If that doesnt help it sounds like a new cat and new injectors. Unless the auto's are that much different than a stick that was my only other thought where power loss would be impacted vs others. Thanks again
Old Jun 20, 2011 | 10:12 PM
  #36
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Do you know what gears are in the rear? If its highway gears like the later 2.59 A4s, You'll be trying for a while to bust them loose easily from a stand still. Automatic Corvettes with those highway gears just have a hard time doing smokey burnouts with just a pedal dump. My car with stock 2.59 gears and the automatic could hardly break them loose unless there was a little sand or gravel to help out. Seriously, and in stock trim it dynoed at a normal-ish 253 RWHP. Put some crap tires on there and it will spin them easier if that's what your after. But really, traction is the goal.
Old Jun 20, 2011 | 10:25 PM
  #37
quinten's Avatar
quinten
the goal isnt to do burn outs i just seem to remember it doing that easier years ago when i was younger. I know it does not have the G92 pkg 3.07:1 Axle ratio so i would assume it has the highway option you mentioned. Perhaps my memory from being younger is off and i know until a few years ago it had the original tires on it and those were im sure not as grippy as the new ones not to mentioned hard and dry so they would slip more easily. Thanks for the help. I just want to make sure nothing is wrong with the car and that it is running correctly. My goal isnt to go tearing around town doing burn outs i dont do that with any of the other cars i have if it can do it its just nice to know and who doesnt like like once in a while just lighting them up
To c4 performance
Old Jun 20, 2011 | 11:34 PM
  #38
vader86's Avatar
vader86
Really doesnt require more than mid-grade gas on an 87. 93 octane is wasting money.
Old Jun 20, 2011 | 11:36 PM
  #39
vader86's Avatar
vader86
Don't throw money at injectors until you know theyre a problem. Hook up a fuel pressure gauge to the rail and check the pressure at idle and then shut it down, and note how long it holds.
Old Jun 20, 2011 | 11:59 PM
  #40
quinten's Avatar
quinten
How long am I looking for it to hold and what pressure am I looking for?
