c4 performance
Old Jun 21, 2011 | 01:41 AM
  #41
Ricky 91 vette's Avatar
Ricky 91 vette
Originally Posted by muzikmanwi
Another great place to buy parts they have great pricing on Magnaflow just follow the directions for an email with your discounted price.
http://www.performancepeddler.com/default.asp
I installed magnaflow system in my 91 coupe and I'm regreting it!! It's way too loud and it gets me dezy!!!! I would suggest to keep the stock mufflers !!!
Old Jun 21, 2011 | 11:11 AM
  #42
quinten's Avatar
quinten
So I verified that my axle ratio is the 2.59:1 not the performance 3.07:1 if I wanted to change this to the performance is there anything else that would need changing? I'm thinking maybe speedometer stuff?
Old Jun 21, 2011 | 02:42 PM
  #43
Ricky 91 vette
you will be looking for around $1500 for the axle upgrade, and then a custom coputer tune to fix your speedometer, i have 2.59 too in my 91 auto, and i can smoke the tires at a dead stop easy, if i would be u, i wouldn't mess with the axle, just make ur car breath better with changing its exasut system
Old Jun 21, 2011 | 04:29 PM
  #44
dolbnyc's Avatar
dolbnyc
I had same issue when I got mine. I cleaned out the intake with carb spray and also added some gas treatment.The power came back after I used up the tank of gas that was in there and drove around more. could just be old gas
Old Jun 21, 2011 | 04:58 PM
  #45
bsmutz's Avatar
bsmutz
Try taking off in first or second gear, too, if you haven't already. I was quite pleasantly surprised after leaving the line in drive all the time and then one day taking off in 2nd.
Old Jun 21, 2011 | 06:37 PM
  #46
vader86's Avatar
vader86
You are looking for the fuel pressure to stabilize and hold steady while the car is running, then for it to hold steady after shutdown for several minutes.
Note what the pressure is, and note how long it takes to drop.
You do not need to spend the cash to go to 3.07 from 2.59 on an L98. Other mods should come first.
Old Jun 21, 2011 | 08:26 PM
  #47
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
+1
Fix the exhaust and other low cost mods first. You would do well to look at Vader's site before spending a bunch of money.
Old Jun 21, 2011 | 09:06 PM
  #48
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
I bought a 307 rear from a guy here on CF to replace the 259 for $450. A local mechanic just started a business repairing/modifying cars. $250 to install. There was a big difference in SOP acceleration, and I added a $30 speedometer gear to correct the speedo reading. It is accurate based on my GPS. I will not touch the computer until I change the intake/exhaust. But since I don't race it anywhere, my money will now go to maintaining the appearance.
Old Jun 21, 2011 | 09:15 PM
  #49
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
FlowMasters Series 50 on my stock 88. Better than stock and no drone.
Old Jun 21, 2011 | 09:57 PM
  #50
quinten's Avatar
quinten
Alright I'll look at the intake and clean out if needed. What is the site I should be looking at?
Old Jun 22, 2011 | 12:43 PM
  #51
Stu 91 drop top's Avatar
Stu 91 drop top
my 91 bogs from the line if you just stomp on it. hold the car with lightly your left foot on the brake, accelerate until the rears start to break free - give her more gas and let go of the brake, should smoke away with some practice. - old fashioned brake stand! 2500 RPM or there about.
Old Jun 22, 2011 | 02:02 PM
  #52
Redghost's Avatar
Redghost
St. Jude Donor '10
My '85 sat for a few years and was only started a few times. When it came time for the "smog check" it didn't pass due to the "cat". I put on a new cat and it passed. But, it was like driving a different car. Could it break the tires,,,,,,,, "you bet".
It will shock you how much a "blocked" cat can hurt performance
Old Jun 22, 2011 | 11:43 PM
  #53
quinten's Avatar
quinten
well ordered a new front y pipe without precats and a new high flow cat. Cant wait to get them on the car. What other easy/low cost mods can be done to add power? Cat back is next not sure which one to go with tho. Apprecite the help.
Old Jun 23, 2011 | 01:35 AM
  #54
Rodney_Gold's Avatar
Rodney_Gold
What stupidity possesed GM to put in a 2.6 rear end in a performance car , I dunno!!!
I put in a 3.55 Ratio and my stock 86 is a different car , best bang for the buck upgrade. Tyres bust loose in 1st, 2nd and sometimes into 3rd. I now don't get embarrased at the stoplights. You actually will get better accel off the line if you can spin the tyres a bit but get grip as the motor gets into a sweet powerband. if you dont want to change the rear , you can try a higher stall torque convertor..like a 2500 street stall...
If you want good Mileage then get another type of car...
Old Jun 23, 2011 | 02:10 AM
  #55
cv67's Avatar
cv67
St. Jude Donor '05
Spin them through all 3 gears stock huh.
Old Jun 23, 2011 | 09:01 AM
  #56
joe paco's Avatar
joe paco
Really doesnt require more than mid-grade gas on an 87. 93 octane is wasting money.
I agree. the mis-info about octane ratings is rampant. try using premium in gasoline motors, lawn mowers, etc. the flame retardent chemicals cause a "no burn."
used 87 in my 91 for 3 yrs, never once heard detonation, tried 93 and saw ZERO noticable change, other than expense.
saludos
Old Jun 23, 2011 | 10:36 AM
  #57
NHRalph's Avatar
NHRalph
In my 1986 C-4 I can light up the tires [retty good and it is completely stock. When I first got the car, it seemed to lack power. I discovered a small leak on the intake. Changed the intake gaskets and it ran much better. My cars seem to run better a week after I take them out of the barn from being cooped up all winter. (I do start the cars every week though and let the oil flow) Drive the car with fresh (regular) gas and see if things smooth out. Don't waste money chasing a few horses.
To c4 performance
Old Jun 23, 2011 | 12:03 PM
  #58
quinten's Avatar
quinten
Is yours a stick or auto? Also what rear do you hav sounds like it all makes a difference
Old Jun 23, 2011 | 01:35 PM
  #59
BADDUCK's Avatar
BADDUCK
Go to www.corvettecentral.com they have a pair of OEM style dual outlet no drone mufflers for $220 per pair. They also have rear Y pipes with or without crossover.
Old Jun 23, 2011 | 02:04 PM
  #60
NHRalph's Avatar
NHRalph
If the car was faster when you were younger, I doubt if the rear gear ratio will make that much difference. In my years, I have spent countless hours and thousands of dollars chasing horsepower. I stopped doing that years ago. My cars are fast, reliable and I save mucho deniero, to boot.
We can spend a lot of money gaining more and more power, but now that the Mustang and Camaro V-6's have over 300 hp..It's a never ending pursuit!
