Vortec engine block replacing a L98 engine??
Old Jun 23, 2011 | 07:20 PM
tjwong's Avatar
tjwong
Default Vortec engine block replacing a L98 engine??
Anyone know for sure if a vortec 350 truck block from a 99 GM truck would be a direct bolt in to replace a L98 engine block in a 86 C4? Got a customer wanting a 383 build and I have a Vortec 350 truck block to build with.
Old Jun 23, 2011 | 10:08 PM
RWDsmoke's Avatar
RWDsmoke
Everything fits. I have a 96 vortec truck block in my 86.
Old Jun 25, 2011 | 01:22 AM
tjwong's Avatar
tjwong
Cool, did you use the original Vortec timing cover as well? If so how did you plug the Vortec crank sensor hole?
Old Jun 25, 2011 | 10:59 AM
rklessdriver's Avatar
rklessdriver
The last one I built (using a 96 Vortec block) we re-used the timing cover and oil pan off the L98 that came out of the car. This was in a 91 6spd.
Will
Old Jun 28, 2011 | 09:53 AM
tjwong's Avatar
tjwong
Will
Cool, thanks for the information.
Old Jun 28, 2011 | 01:18 PM
tpi 421 vette's Avatar
tpi 421 vette
The only real difference is there is no dowels in the block for the timing cover. The dowels are cast into the plastic timing cover. By the book, you aren't suppose to reuse the plastic timing covers, your suppose to replace them. But if it's in good shape, you could probably get away with reusung it. And you can also get the timing cover dowels, tap them in the block, and use any SBC timing cover on it after that.
Old Jun 29, 2011 | 09:02 AM
RWDsmoke's Avatar
RWDsmoke
I used a new plastic timing cover without a hole from Scoggin Dickey. if you use the vortec harmonic damper you have to leave the reluctor ring in for a spacer. With aftermarket damper take it out.
Old Jun 29, 2011 | 10:57 PM
tjwong's Avatar
tjwong
Is this the cover you got?
http://sdparts.com/details/gm-factor...parts/12562818
To Vortec engine block replacing a L98 engine??
