Page 8a-11-0 of the electrical suppliment (brought it to work today) shows a 10A VATS fuse in the lower left corner of the fuse block. I suppose it wouldn't hurt to pull it out and re-insert it---maybe even "scrub" it in a little---to be sure there isn't a contact problem.
Reason: lower left
From: MotherLode - Sierra Nevada Mountains California
Hey Sammy, WHAT UP with the anti-climatic ending?
Did you ever figure out the problem?
I am curious because I have a topic going for my '94. http://forums.corvetteforum.com/c4-t...-94-coupe.html
It just quit working.
Your thread gave me a couple of more directions to go, I was stalled out.
My biggest concern is that my LCD display is blank. BIG $$$ if that is also a problem. I'll be taking the column apart tomorrow to examine the "two white wires", then I'll try and find the starter relay switch.
If your 'Vette is fixed, could you chime and help with the solution on my thread or this one?
Thanks- RACER X
