Opti Options??? 96 LT4
Old Aug 12, 2011 | 12:19 AM
tinbender59's Avatar
tinbender59
Hum, interesting point's brought up here. As an electronics tech I can tell you that LED's are very robust, that includes receivers. I was brought into reality by one of the posts, unless you have experienced a major high voltage issue, the electronics should be ok,,that is should be ok. so I would be interested to know, those of you that have a bad OPti's out. Take a cotton swab with rubbing alcohol and swab both the transmitter's and receiver's. (the disk rotates between them) Then look at the swab to see if it has some contaminates on it. let us all know? if you do get yuck off of it, reinstall it and see if it is cured. remember there is more than one set as well.
Old Aug 13, 2011 | 10:42 AM
SouthernSon's Avatar
SouthernSon
Just put an MSD ProBillet in my '96 last week. I yanked a $600 dynaspark out that was installed last Dec. and has less than 3K miles on it. Car would miss, stall and finally died on the highway. Towed it to dealer but with no codes they were at a loss. It died twice in the service bay. I trailered it to my house and installed the MSD. Now the car runs strong, with no misses and has a couple of hundred miles on it with no issues. I will update this forum on Dynaspark's response to my problem next week. I would have to say at this point I do not hold Dynaspark in high regard.
Old Aug 13, 2011 | 12:11 PM
jrbollman's Avatar
jrbollman
Originally Posted by jrbollman
Got the new GM opti and checked the sensor. Found a Mitsibishi optical sensor. I hope that's a good sign. We'll see Friday what the MSD has to tell us, when we get to look inside.
Good news... Installed new AC Delco optispark. Bad news... Car won't start. Grrrrr
Looks like a bad new optispark. The jury's out on that but mechanic will have to eat shop time. Got spark and got fuel. The only thing we did was change the optispark. Of course, could it be the itermitten dying we started with. The MSD looked good internally. More latter.
Old Aug 13, 2011 | 01:03 PM
mtwoolford's Avatar
mtwoolford
an easily overlooked...and delicate...item prone to corrossion (at least mine was) is the low voltage wiring harness that plugs into the opti; the opti design makes the terminals on the end of this harness darn near impossible to clean except for shooting with an aeresol electrical cleaner. But since the the foot long, four wire harness sells for as low as $25 ( I paid $37 for mine) brand new why even try ? This is one area where "repair by replacement" makes sense (p.s. don't go to the dealer...it had to be a misprint, but I was quoted $250 )
Old Aug 13, 2011 | 01:21 PM
SouthernSon
Good point. I always glob a bunch of dielectric silicone on the end of the plug and jam it together. No corrosion on my electrics.
Old Aug 13, 2011 | 03:19 PM
helphos's Avatar
helphos
Default Chandler Optisparks
Originally Posted by mmracecars
Have used the delco,msd ,and dynaspark in my race car(procharged camaro) and had alot of failures,either misfiring or rotor would explode.i dont think delteq exists anylonger.was using the chandler lifetime units fo 134.00$ with good sucses,but i heard they have doubled the price,so i guess whatevery you try,just remove the cap and loctite the rotor screws and hope for the best.
mike
I just installled a Chandler Optispark unit. They raised the price, but it's not doubled. I paid $174 for the lifetime warranty model. Before I installed it I Loctited the screws and put a bead of RTV around the mating surfaces just in case the water pump decided to go south.
I think most people who have a DOA unit are not getting the opti properly lined up on the shaft, and forcing it out of alignment. The alignment is subtle, and misalignment is fatal.
Anyway, I put my Chandler on last week and my 93 vert is running better than when I got it 18 months ago!!
BTW, as it was dying, the opti threw no codes. There were lots of carbon tracks in the distributor cap however, upon autopsy.
Old Aug 13, 2011 | 04:26 PM
mfi's Avatar
mfi
If you change the opti I would pull change the coil and control module and clean up that heat sink which is sure to be packed with grime...another $150.00 can't hurt and turned out to be the main prob with my car...
Old Aug 13, 2011 | 04:56 PM
pcolt94's Avatar
pcolt94
I can't completely disagree with mfi but have a suggestion.
Change one item at a time, opti, ICM, coil. That way if you have a no start problem, you will know what you did last rather than having the back track to find the cause.
It may take longer doing it this way but so what, there's no race and the customer is not picking the car up at the end of the day. It's just being methodical when changing a lot of parts or doing several things at one time avoiding a new set of problems or circumstances.
Old Aug 13, 2011 | 05:14 PM
1963SS's Avatar
1963SS
Yep, that's a good idea.
Old Aug 13, 2011 | 11:59 PM
jrbollman's Avatar
jrbollman
We did have to scramble to find a opti wiring harness. The MSD has it's own. It was a used harness. I ordered a new one, it will be here Monday. We probably should hold off on pronouncing the AC Delco DOA, until I try a new wiring harness. Thanks for all this good stuff. I can't believe this can be so hard to get right.
Old Aug 14, 2011 | 02:48 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Did you try testing it for continuity? What about bending the contacts back out so they make firm contact? Cleaning them?
This is a simple piece, its 4 bits of stranded copper core wire and 2 simple plugs, it will not take any effort or even any special skills to test this item.
Old Aug 14, 2011 | 10:12 AM
mfi's Avatar
mfi
Reason I say change the coil and module is its a 20 minute job...if I had done it first I would have been on the road again that day..instead of 3 weekends changing ..everything else..but I'm glad I changed everything ..the car runs better than EVER!..but you say you have spark..I did not..but if your coil and module have a lot of miles on them..its just a matter of time before they start to go anyway..let us know how it going..
Old Aug 14, 2011 | 10:17 AM
  #33
helphos's Avatar
helphos
That's exactly what I did. I did it in the order of cheapest, first, though!
I would have jumped off a bridge if i did the Opti first, and it hadn;t been the real culprit. This way I may have "wasted" some money by replacing things that were still functional (but perhaps next in line, anyway) but at least when I got to taking out the water pump, the harmonica balancer and the Opti, I had a high degree of certainty that it would fix the problem! And it did!
Old Aug 14, 2011 | 10:38 AM
  #34
C4fan's Avatar
C4fan
St. Jude '10
It's not hard at all to remove the wires from the plugs on the harness. I had to use my original harness but with the new style plug on mine when I switched from early opti to the vented. If anyone is interested I can take pics and show how. It's very easy, no cutting.
Old Aug 14, 2011 | 11:04 AM
  #35
jrbollman's Avatar
jrbollman
Mechanic seems to thing the timing is off in the new opti. We have fuel pressure and spark indicating signaling from the opti thru the harness. He has ordered another Optispark (AC/Delco) but I think we should try the new wiring harness before we give up on the new optispark.
Old Aug 14, 2011 | 11:10 AM
  #36
1963SS's Avatar
1963SS
Why would you care about the weight of your harmonica?
Old Aug 14, 2011 | 11:38 AM
  #37
mfi's Avatar
mfi
only way timing could be off is if it was put on wrong or the sensor disk is screwed up..
To Opti Options??? 96 LT4
Old Aug 14, 2011 | 12:29 PM
  #38
jrbollman's Avatar
jrbollman
That's the way my mechanic sees it. We'll find out tomorrow.
Old Aug 14, 2011 | 07:58 PM
  #39
Casethecorvetteman
All the leads in the right order? As MFI says, the timing cant be out unless it is put on wrong.
Old Aug 14, 2011 | 08:04 PM
  #40
STL94LT1's Avatar
STL94LT1
only way timing could be off is if it was put on wrong..
