Crossfire brainfart. Could it work?
Old Aug 17, 2011 | 11:07 AM
  #41
qws's Avatar
qws
Originally Posted by Lemme
Why don't you recommend the Xram? Seems as good as anything else. I suppose putting in an 2500 TC was out of the question for GM?
Its no longer made. Of course you can always search for a used one.
I think GM used a TC that was more like a 1500-1600
Old Aug 17, 2011 | 03:58 PM
  #42
Rohn's Avatar
Rohn
XRam has fuel distribution as well as drivability issues in a cool climate. that plenum never gets warm enough. Design constraints as the plenum floor is like an inch from top plate of plenum. Injector spray is onto plenum floor. Convoluted path from plenum floor to intake port (Z).
I took mine off and replaced with this: Holley Projection dual plane manifold(rated 6500rpms) with GM 454 TB.
[IMG][/IMG]
Here is my XRam note plenum depth under TB units.
[/IMG]
Old Aug 17, 2011 | 08:22 PM
  #43
Lemme's Avatar
Lemme
St. Jude Donor '10
[IMG][/IMG]
That looks promising.
Old Aug 17, 2011 | 08:25 PM
  #44
cv67's Avatar
cv67
St. Jude Donor '05
Agreed, if youre not hung up on the "dual" thing that single TB is less hassle and those intakes work good on 350s. Like a carb setup but not...better.
Old Aug 17, 2011 | 08:34 PM
  #45
Lemme's Avatar
Lemme
St. Jude Donor '10
Looks like a $1000 job (+ freight) though but probably worth it. Changes to fuel lines, throttle cable, inlet ducting and air filter. I presume it would need to be custom fitted.
Old Aug 17, 2011 | 08:58 PM
  #46
ex-x-fire's Avatar
ex-x-fire
I did the single tbi swap years ago, you can reuse the throttle/tv cables, make the cruise control work. Fuel lines are not a big dea & the stock pump will run the tbi. The beauty of it is you can use the stock ecm & harness, its mostly plug & play. Hood clearence can be the issue, you'll have to measure very carefully.
Old Aug 17, 2011 | 09:39 PM
  #47
Lemme's Avatar
Lemme
St. Jude Donor '10
If people are doing it then hood clearance can't be a major hurdle. Is there a second hand market for this arrangement or is it a buying brand new proposition? Do both TBI fire at the same time now? Is the single replacement equivalent to the two being replaced in terms of fuel metering? Retuning required?
Old Aug 17, 2011 | 09:58 PM
  #48
87 vette 81 big girl's Avatar
Steve,
There has been 2 of those Renegade Intakes for sale in C4 parts in the last 1 week.
I don't know if you caught that or not.
Around $450 or $600.
1 of those Renegade Intakes for sale was In Wheeling, IL.
Also,
another C4 forum member that is on C4 ZR-1 that races his "Z" spoke up on that C4 parts - Renegade for sale.............
He stated the Renegade is really a Wieland intake with a different casted top with the Renegade logo.
Not so special to me that Renegade Intake.
After what you went through................I would not give $ .50 cents for it.
Brian
Old Aug 17, 2011 | 10:12 PM
  #49
Still think the renegade is worlds better than the best worked over crossfire.
Now a worked Renegade, hmm. Too bad you cant get one!
On how far you can go thats hard to say without either going through one or having a sonic tester handy. One day....$$$
Brian thanks for the words, Im just a backyarder though. Appreciate it.
Those runners are long enough I wouldnt worry about airspeed or puddling, most that is old school thinking from the 60s of guys overjetting their Holleys and fouling plugs. Thats where the advantage of EFI/TBI comes into play bet you could polish them like mirrors and it will run the same as if they were rough. Just an opinion thats all.
I am just a little guy mechanic too Ron.
I have been to every racing shop in Illinois 1 time or another.
Seen the head porting work they have done.
I have been to INDY Head Racing Service in Indianapolis, Indiana.
The owner Russ showed me around & wooed me with his own porting workmanship.
From the photos you shared on C4 in the past>>>>>>>>>>>>>>>
YOU ARE BETTER & DO MUCH CLEANER PORTING WORK.
I can make my own calls.
You are better than most out there porting Intakes & Cylinder Heads.
Brian R.
Old Aug 17, 2011 | 10:19 PM
  #50
Lemme's Avatar
Lemme
St. Jude Donor '10
Originally Posted by 87 vette 81 big girl
Steve,
Also,
Brian
Not sure whether the Renegade is what I really need. I want a really quick 84.
Old Aug 17, 2011 | 10:30 PM
  #51
I am pretty much over the renegade. Apart from getting my money back I have no other interest in it. Still waiting for that money btw! Not sure whether the foundry is holding up the transaction reversal too!
There is NO CASTING FOUNDRY STEVE,
It is a Weiland Intake Design & Product.
That guy made his own adapter top with his Renegade Logo.
He fooled the entire C4 world................................... .................
And even my buddie in Australia>>>You Steve.
Old Aug 17, 2011 | 10:31 PM
  #52
That guy in Arizona needs his *** kicked by someone like me...
Old Aug 17, 2011 | 10:43 PM
  #53
Lemme's Avatar
Lemme
St. Jude Donor '10
I am quite interested in the single tb idea with the dual plane mainfold. Would it be also be possible or worthwhile putting my L98 128 heads on the L83? 76cc iron heads to 58cc aluminium heads: 9:1 to 11:1 cr may be too high I think? My heads have been milled so may be only 54cc. Have to change the cam to lower the dynamic compression ratio.
Old Aug 17, 2011 | 11:15 PM
  #54
Yes.
I think so Steve.
Old Aug 18, 2011 | 07:30 AM
  #55
ex-x-fire's Avatar
ex-x-fire
Lemme, I'll get you some part numbers on the stuff I used. The intake I used even came with throttle/tv cable brakets.
Old Aug 18, 2011 | 07:34 AM
  #56
Lemme's Avatar
Lemme
St. Jude Donor '10
Great. Put it up here as a kit for anyone else to follow too.
Old Aug 18, 2011 | 08:26 AM
  #57
ex-x-fire's Avatar
ex-x-fire
Ok, the intake I used was the Holley 300-49, it included a tbi gasket, egr hardware & block off plate, throttle/tv cable brackets, & intake bolts.
The tbi that I used was the Holley 502-6, it has 2" bores & a adjustable fuel pressure regulator. Or you can use a tbi from a 87-89 Chevy truck w/ the 5.7L motor. This tbi has smaller bores the the Holley, but the price is much more reasonable (junkyards/swap meets).
Some guys have used the GM 454 tbi unit, it has a different iac connector & some did not have a tv cable connection on the throttle arm.
To make the fuel lines, remove the fittings from the cfi tbi units & put them on the single tbi. These lines are 3/8 & 5/16, they used a double flare (atleast on my 84). I went w/ the fittings from the newer tbi units, this is a flare w/ a o-ring. Use Dorman 800-153 & 800-151, sold at all the chain stores.
Like I said the air cleaner will need to be carefully measured, I had to trim a K&N element to clear, you can see the picture of my engine in my avatar. Those carb hats may work good too, Spectre has a new one that looks cool, Spectre 865-728.
To Crossfire brainfart. Could it work?
Old Aug 18, 2011 | 03:32 PM
  #58
84cfi's Avatar
84cfi
The intake you are talking about is the X-Ram with the weiland gotten with the adapter top. I know this because I have an X-Ram. I installed a renegade because I was told it is better. But who is to say I have never seen a side by side comparison.
Old Aug 18, 2011 | 03:39 PM
  #59
84cfi's Avatar
84cfi
If you are looking for an X-ram I could hook you up. I have one at home on the shelf. It is the latest version, the first 3 versions of the x-ram were not so good. The one I have is version 4.
Old Aug 18, 2011 | 06:56 PM
  #60
Lemme's Avatar
Lemme
St. Jude Donor '10
THe big ticket item here is the TBI. $500 new! Manifold is good value - only $200 inclusing all the brackets / adaptors required.
