Budget 2-row radiator comparison
I may also be able to improve the situation by pulling the shrould back off (outdoors), stick cardboard between the radiator and condenser and spray/clean the condenser. When I installed the 2-row (in my garage), I didn't want to drag the garden hose in there and make a mess. More air thru the condenser may help when it (condenser) gets hot.
FWIW, My temps stay between 190-200 w/o the A/C turned on (according to the dash). (Temps are 10-deg less at the thermostat.)
Occasionally, it will eek up to 201-202 if I sit long enough (10-min). If I turn on the A/C on a 100-deg day, it'll climb 1 or 2-deg each minute. But, only if I'm sitting still, idling. Once rolling, temps will fall back into the 190-200 range even with the A/C running full blast. (My A/C is super cold and has never had freon in 22 yrs!!!)
My compression is 10.25 SCR and 8.25 DCR. My DCR is higher than many 11:1 engines with 220-230 duration (intake) cams.
Seems like you'll be better off with LOWER temps than I'm running. Your compression is higher. (Hence my comments to you in this thread).
You may also need a higher CFM water pump (or electric pump) as Engle, jfb, LT4Bud, and others have suggested in this thread.
Let's just say waiting for a cooler day isn't the best (or normal approach). I wouldn't want those temps with a 10.7:1 engine. I'll add that those looking at buying a Champion radiator might not be impressed by the temps you reported above. There are reasons for those temps you don't seem to want to address -- reasons that a radiator and oil pan won't address.
Let's just say I'm not impressed or think you're doing the right thing. If you bothered to look at Vizzard's temperature recommendations for high compression, you'd see why.
Maybe you think you've got things covered, but I think you're nuts. And, that includes building for mere street operation. You haven't done your homework.
Maybe you're O.K. with the knock sensor kicking in (all day long) on hot days and removing timing to back off detonation. I hope your ESC never fails. Trusting your build to a mail order chip from Alvin isn't what it takes to build for performance power levels.
Tell him Brian and Ron.
Quit Burring Greg's dick in the dirt.
He has been honest & I appreciate his input.
No 2 C4's are the same.
Neither are driver's.
Any of you guys find a radiator to cool a C4 down the highway at 140 F running at 160 MPH do let me know.
Like I stated before when not so Hot outside the car Temps are great today it was 108 outside I drove my Expedition today the Vett stayed in the Garage today.
The fun part about driving the Family car reminds you how fast the Vett is and when getting back into the Vett put that stupid grin on your face when you fire it up and take off from the stop light.
My question is, i saw it mentioned about how the temps read by the gauge at the cyl head is about 10 + deg hotter than what is read at the front of the plenum near the thermostat.
Is it possible to route the wire that normally goes to the pass head up to the sensor in the front of the plenum? I know the one in the head is a single blade and the other is a dual. But maybe it could still pick up the signal off one of them? it will still go to the comp but that way you can get a more accurate reading in relation to what the thermostat and fans will be doing.
Then again the fan is based off of a sensor in the drivers side head if i'm not mistaken?
can't take that long to make . . . . How much was the Dewitts one?
Also, the new 2-row models just came out. Gotta think they have lots of those too.
Good question about converting/connecting the CTS with the PS head coolant sensor. However, for someone tuning their motor, I wouldn't consider that necessary. Just observe the temps at the cylinder head and program accordingly.
For example, if you want your fans to come on when the passenger-side sensor is sending your dash 200 for a temp, you'll probably be around 190 at the stat. Code 190 as the turn-on in your BIN and see how close you get. Adjust if necessary.
Set your turn-off point about 5-degrees lower than the turn-on point.
To adjust the AUX fan function, you need to find an aftermarket DS sensor with different on/off points. There are a few.
Or you can wire the aux and main fans together. I know people do that for manual turn-on BUT I don't know if they've done it for ECM control. It should be doable since the ECM is indirectly controlling them thru a low-power relay. If both fans [wired together] overload the relay, upgrade to a higher amperage relay.
As noted in another thread, the AUX fan's purpose may be to keep the A/C condenser cool. Makes sense, since blowing across the condenser would increase the load on the radiator.
^ I was thinkin of getting one of these greg
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
They have alot of different varieties.
200 on / 185 off
195 on / 180 off (maybe this one)
190 on / 175 off (thinking this paired with 160 stat)
185 on / 170 off
200 on / 185 off
185 on / 170 off
I bought mine for 1/2 that price at Mid-America Motorworks....also a vendor.
http://www.mamotorworks.com/corvette?frame=3.944
Part#609-106
Edit: OTOH, Mine seems about 5-degrees off. It comes on closer to 195 on / 180 off. Sounds like this would work for you. Make sure you lower the program points for your main fan.
If not, you don't have one, but it could be added. If not, you don't need the fan switch. The main fan (as you pictured) is controlled by the ECM.
So i'm guessing then that i could just plug off that hole in the head then. wonder how hard it would be to add a aux fan or if it's necessary. Don't really have any extra cash . . .
If that doesn't cool enough, a higher CFM main fan and/or ewp is your ticket.
Since a higher CFM main fan is the easiest next mod, that's probably what I'll try next. Maybe I'll end up needing the ewp someday. If I didn't want A/C, I'd be good-to-go.
Another thing I could try is lower idle timing to bleed off compression. (I hadn't jumped on this option out of concern for my header coating. I've no idea how low [in degrees of advance] it takes to cook the coating. I bet it's related to DCR.)
Before judging, consider my 383 is running higher DCR that many/most strokers on this forum. My cam is shorter duration. (Marv is in the same boat.)
Theres the rub....
with the upgraded radiator and other minor cooling system upgrades these engines will run all day in traffic with 110* ambient temps and they will sit at 190 and never think about going higher.....
Until the driver starts to sweat and turns on the a/c.
The condensor heat from those high ambients is so great that its hotter than the radiator, so the condensor pushes the radiator heat UP by blowing hotter air into the radiator and driving the engine temp up.
Mine will do exactly as you described...and within 1 min of driving a steady speed again it starts dropping and will end up back around 189-190 everytime. The trick to this (best of both worlds) is to somehow create some fresh air flow at a good rate for the condensor. Sitting at idle the main fan draws air in and thru, but it gets pulled around the condensor thru the side ducts. Its designed that way to prioritize the fresh air and let the radiator get whats available when at idle or slow speed.
I'll be looking into sticking 2 or maybe 3 small 6" fans on the condensor face wired in a switch that I can turn on/off so the condensor is getting some air pulled in when idling in traffic. My belief is that IF I can keep that condensor cooled enough I can run a/c AND keep it from blowing hot air into the radiator.
I have some doubts that a bigger main fan will help because it would pull more air, BUT it would pull it around the condensor thru the side ducts as it does now, and the key to keeping the whole mess at a reasonable temp is that overheated condensor thats starving for air at stop lights...and making the a/c system go to high pressure and cutting it out until it gets some air flow again...
Then again, this could easily be a no-win situation with modified engines and air conditioning..and stop & go traffic.
This extraordinary summer heat sucks.......
