Electronic Gauges
Old Sep 27, 2011 | 05:21 PM
gdoster's Avatar
gdoster
5th Gear
Default Electronic Gauges
1996 LT-1 When I push the gauges button I get a zero reading on everything, Zero volts, zero temp zero all. Is there a wire off somewhere, everything else is working fine.
Old Sep 27, 2011 | 10:51 PM
pcolt94's Avatar
pcolt94
This could be a difficult problem to target. All the different temperatures and displays are inputted by different sensors to the CCM. Your gauges button inputs to the CCM and is changing the display. Sounds like the CCM is not processing the information correctly or there might be a connector problem. I would focus in on the CCM area. Maybe reseat the connectors and or clean them. Remove the battery connector first.
If I were to troubleshoot this myself, I would connect my Tech1 (or scanner) and look at the serial bus. This would tell you if the CCM is receiving the information you are missing or otherwise. If you don’t have a scanner, I would check for any codes using the on board diagnostics. Even if there are no codes, you want at least to know if you can interrogate the system and get a C12 and know that communication is functioning.
Old Sep 28, 2011 | 10:27 AM
engle1147's Avatar
engle1147
Probably just a problem with the cluster's switch panel or it's connections. Did you just buy/get this car?
Old Sep 28, 2011 | 10:37 AM
gdoster's Avatar
gdoster
5th Gear
Thanks. I did just buy this car from the original owner, and this is the only thing I can find wrong with it. Thanks again
Old Sep 28, 2011 | 10:39 AM
engle1147's Avatar
engle1147
Welcome to the Fourm....enjoy the car.
To Electronic Gauges
