C4 backup lights
Old Sep 27, 2011 | 09:25 PM
malcking1's Avatar
malcking1
Cruising
Default C4 backup lights
My 91's back up lights are always on, no matter what gear-manual-Iam in. I checked switch on trans-OK, fuse-OK. Any thoughts since everyone is smarter than I am.
Old Sep 27, 2011 | 09:41 PM
pcolt94's Avatar
pcolt94
First thing I would do is pull the fuse for the backup lights and see if they go out. If they don’t, then voltage is coming from elsewhere. (which is a hard thing to believe).
If the lights do go out, I would re-visit the backup light switch and look at the voltage from the output wire back to the lamps. Monitor the voltage in other gears. If it stays there, then there is a problem with the switch.
Maybe you missed something.
Old Sep 27, 2011 | 09:57 PM
malcking1's Avatar
malcking1
Cruising
Default Thank you!!
Your advice is very sound...check the voltage elsewhere.
I must have missed all of the above. thank you, again.
To C4 backup lights
