Check Engine Light on 87
Old Nov 7, 2011 | 10:49 AM
siestavette's Avatar
siestavette
Default Check Engine Light on 87
Cold or hot starts, about every 4th time started the "Check Engine Light" comes on? Any suggestions? Thanks
Old Nov 7, 2011 | 02:26 PM
Classy97's Avatar
Classy97
What code/s is the display giving you?
Old Nov 7, 2011 | 03:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You need to retrieve the code(s) in order to know what the problem is, then post the them.
http://corvettephotographs.com/c4vettes/codes.htm
To Check Engine Light on 87
