Hypertech Power Tuning Module
Old Nov 22, 2011 | 09:49 PM
Docderek05's Avatar
Docderek05
Default Hypertech Power Tuning Module
Hello all,
Does anyone have experience with a Hypertech Power tuning Module,
the type that plugs into the stock ecm then the ecm plugs into the module?
Is this worth the $250 plus for the unit, and does anyone have one installed with their 1993-94 ecm? and what kind of results have been noted.
I am interested, but I am hoping this is not a negative that could hurt my electronics, and ultimately the power train in general.
in other words is this just a pig in a bow tie, or an effective unit to slightly increase my stock performance, without doing major mods.
Thanks for the advice, Derek
Old Dec 11, 2011 | 10:06 PM
THE 383 admiral's Avatar
THE 383 admiral
get a real tune with your car on a dyno... don't waste your money
if your stock.. get some upgrades then tune on a dyno
92 - 93 is a Prom like 86 - 92
Old Dec 11, 2011 | 10:22 PM
BLOWNALKY01's Avatar
BLOWNALKY01
Originally Posted by Docderek05
Hello all,
I used to run a Mustang chassis dyno and on a couple of occasions I had the opportunity to do back to back pulls with and without these units. No discernable difference! I then would unstrap, test drive for 20-30 miles, strap back down and retest. Each time negligible gain to no gain. However, each time this was on a Mopar product, but I don't believe it will be any more effective on a GM product. I don't believe, based on my first hand experience, that they are worth anything!
Jack.
Old Dec 15, 2011 | 03:56 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Old Dec 16, 2011 | 12:54 PM
pcolt94's Avatar
pcolt94
It will not tune you engine. It will change fan turn on points, I think shift point and something else.
It is also deadicated to only one car per VIN # (VIN locked) at one time.
Old Apr 20, 2014 | 11:29 PM
stick1977's Avatar
stick1977
4th Gear
Hi, a quick ?, If I were to purchase a used programmer and I hook it up and it is VIN locked will it hurt my electronics just because I hooked it up and unpluged it?
Thanks...Peter
Old Apr 20, 2014 | 11:46 PM
STL94LT1's Avatar
STL94LT1
93 and 94 uses different ECM's. So you may want to check the specs before the purchase. Every Hypertech that I have seen for the 94 actually reprograms the PCM.
Old Apr 21, 2014 | 11:04 AM
stick1977's Avatar
stick1977
4th Gear
STL94LT1, please bear with me,I have a 94, are you saying it can reprogram my PCM if it is VIN locked to another vehicle just by hooking it up to my 94 to see if it is VIN locked or not?
Thanks...Peter
Old Apr 21, 2014 | 02:34 PM
STL94LT1's Avatar
STL94LT1
If it is VIN locked to another vehicle then no it won't work on your car, and yes you can hook it up to your vehicle without damage. Should just display that is is locked.
Old Apr 21, 2014 | 08:21 PM
stick1977's Avatar
stick1977
4th Gear
Thank you STL94LT1 !!!!!!!
Peter
To Hypertech Power Tuning Module
