Paperclip method for a '93..
Old Dec 6, 2011 | 03:17 PM
Drew's Avatar
Drew
Default Paperclip method for a '93..
Is Checking codes on a '93 the same as for later years?...I know for 94 and up you check with Pin # 4 and #12 with a 16 pin system.
My '93 has an OBDI 12 Pin system. Do I check for codes with the #4 and #12 pins when using the paperclip method, or something different?
This is my first time trying this so I am just curious...
Man, My '78 L-82/4 speed car is so much easier to work on than this '93
Thanks!
Old Dec 6, 2011 | 05:57 PM
rodj's Avatar
rodj
No
Jumper A + B
http://www.digitalcorvettes.com/foru...ad.php?t=22897
Old Dec 8, 2011 | 08:12 AM
93VettePilot's Avatar
93VettePilot
Originally Posted by rodj
Sorry but this info is wrong. Jumper A to G or just ground pin G. A is a ground to chassis. G is the diagnostic pin.
Old Dec 8, 2011 | 08:19 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
same as a 92
Old Dec 9, 2011 | 04:01 PM
Drew's Avatar
Drew
The A + B thing didn't work for me.
All I got was a clicking noise on the right side of the dash and my cooling fans came on....No codes...
Old Dec 9, 2011 | 07:41 PM
kimmer's Avatar
kimmer
A to G
Old Dec 12, 2011 | 11:27 AM
9T3VETTE's Avatar
9T3VETTE
Originally Posted by kimmer
A to G
This is correct. A to B is NOT correct.
Old Dec 12, 2011 | 12:55 PM
pcolt94's Avatar
pcolt94
A & B is for diagnostic trouble codes.
Pin G is for the fuel pump.
http://www.neilkline.com/Tech%20Tips/obdcodes.htm
Old Dec 12, 2011 | 02:46 PM
kimmer's Avatar
kimmer
Not for a 92-93
Old Dec 12, 2011 | 07:28 PM
93VettePilot
A & B is for diagnostic trouble codes. Pin G is for the fuel pump.
Sorry but you are just as wrong as "rodj". I have a 93 and have performed the A to G method hundreds of times. I also have a factory service manual for a 93 and it says A to G. Guys if you don't know what your talking about then don't cause confusion for others.
Old Dec 12, 2011 | 07:40 PM
pcolt94's Avatar
pcolt94
Not for a 92-93
I give, I give
I just had to see it one more time "you are wrong" to make me go out and find the info again.
So me and RODJ will take it in the neck on this one.
So here is the corect information:
http://tech.corvettecentral.com/2011...trouble-codes/
To Paperclip method for a '93..
