You need the correct driver for the USB to serial converter. If it's installed correctly you can see it in the Device Manager.
Even if you see it in device manager you may have to manually set itup for the communications settings the software is looking for depending onthe age of the software.If it is looking for a serial port rather than usb it is old or written with older software. Generally Ihave had good luck by forceing the com settings to COM 1 8 bits No parity and 1 stop bit 9600 baud rate as these were the defaults onolder machines. You may ormay not have toplay withinterupt vectors and hardware address as well.
I'm a bit baffled. In the last couple of days my '88 has been exhibiting strange behavior. At idle and the first 25% of gas pedal it seems to run fine, but when I when I put my foot in it, it completely flattens out and won't accelerate at all; even missing a bit. When I let off of the gas, it seems to run OK again. Has anyone else experienced this? I would be very appreciative of any guidance.
Have you tried to check for stored trouble codes the old fashioned way - with a paper clip?
It does seem as if you fuel pressure is a bit "low" as compared to a stock 22# setup....but I would think that 30psi with 24#'ers installed wouldn't be low enough to cause a "buck"....maybe a "miss" though.
With the symptoms your describing - my guess - would be an issue with the MAF related circuit, signal and/or sensor.
OK, I bought a fuel pressure tester, connected it, and taped it to the windshield. Idle pressure is right at 38. When I got on it hard it still flattened out and started to miss & buck again, but at no time did the pressure gauge go below 30. With 24# injectors, I would think that this should be enough. When I let off the gas and drive gently, all seems normal. I've been assuming that it is a fuel delivery issue, but maybe it's a spark problem. I couldn't find anything in the FSM that addresses this symptom. Any ideas? This has me stumped.
You need to return to addressing your fuel delivery problem. Your info shows there is a problem there, fix that one and move forward.
38 at idle is acceptable, but dropping, instead of increasing under load, is not acceptable.
Am I wrong in my assumption that I should be able to hear the fuel pump re-charging the fuel rail pressure? It seems to me that I used to ba able to hear it..
The ECM will energize fuel pump relay for 2 seconds, when ignition is first turned on. It then waits for reference signal from distributor, before it will continue to send power to relay.
There is a timer, so quickly turning the ignition on and off, will not keeping applying 2 seconds of power to relay. I don't recall how many seconds must pass before the ECM will again energize relay, but it's less than 30.
Agent 86, your advice to stay focused on the actual problem was right; I was getting sidetracked on the Turbolink connection stuff.
Here is where I sit now. I replaced the fuel pump and filter. Problem still persists. I replaced both of the MAF relays; problem is still there. Finally, I just disconnected the MAF sensor and the car started to run normally.
When I checked the codes (paperclip method) it was storing 33,34,36 and 54.
After clearing them, it is now showing only 34, with the MAF connected.
Clearly, the MAF appears to be the problem; I'm just a bit embarrassed that I didn't try the "just disconnect it" approach earlier.
Now that I have (hopefully) narrowed it down, I am trying to figure out which MAF sensor to buy. Given my current finances, a new one for $700-$800 is out of the question, so I have to go refurbished. I am trying to find out which rebuilds are Bosch, which have wire burn off capability; apparently ACDelco's do not. Not sure if I should even be concerned about this; I may just end up with the Cardone rebuild at AutoZone for $130. I would welcome advice from those who have been down this road.
My sincere thanks to all of you who have provided guidance with this.
