I'm a bit baffled. In the last couple of days my '88 has been exhibiting strange behavior. At idle and the first 25% of gas pedal it seems to run fine, but when I when I put my foot in it, it completely flattens out and won't accelerate at all; even missing a bit. When I let off of the gas, it seems to run OK again. Has anyone else experienced this? I would be very appreciative of any guidance.
I would check your fuel pressure while running first..If you have a pressure gauge screw it to the fuel rail and lay it flat against the windshield so you can check the pressure while driving. Watch the gauge while you run through the rpm trouble area and see what readings you get...If its not the fuel pressure then you have to start testing to find out if this is being caused by fuel or spark. It could be quite a few different things causing this and you have to test to find out which one it is..This is where a factory service manual really comes in handy.....WW
OK, I bought a fuel pressure tester, connected it, and taped it to the windshield. Idle pressure is right at 38. When I got on it hard it still flattened out and started to miss & buck again, but at no time did the pressure gauge go below 30. With 24# injectors, I would think that this should be enough. When I let off the gas and drive gently, all seems normal. I've been assuming that it is a fuel delivery issue, but maybe it's a spark problem. I couldn't find anything in the FSM that addresses this symptom. Any ideas? This has me stumped.
another possibility could be the spark plug boots have backed away from the plugs, at idle and low power the arching is Sufficient to keep the engine running, under a load it's a whole differant story..
If the FP at idle is 38 that would make sense as I had thought it should be 45 with key on engine off or the vac line to regulator disconnected with engine running. If you went down in pressure when you got on it you found the problem or one of them at least, the fuel pressure should have gone up to 45 psi not down to 30 psi. There may be other problems with ignition or other sensors but this is not right as you describe it.
Dave
Dave
I relieved the fuel rail pressure via the schraeder valve, and turned the key on. Shouldn't I hear the fuel pump chattering to rebuild the pressure? I hear nothing. Does this tell me anything?
Did you turn the key on several times? (sometimes it takes more than once) Do you get fuel out of the valve after charging the fuel rail?
You might be better off trying a fuel filter change if it hasn't been done in a long time. Other than that I wouldn't start throwing parts at it unless you can get some data. Fuel pressure reading is a good start but if you can connect to your ECM and record data it will probably tell you where to concentrate your efforts.
Yes, your point is well taken; I don't have the dough to get caught up into the "throw parts at the problem" cycle. Am I wrong in my assumption that I should be able to hear the fuel pump re-charging the fuel rail pressure? It seems to me that I used to ba able to hear it. What's making this particularly frustrating is that I have Turbolink 4.0, which would possibly tell me a lot if I could get it working. The problem is that it requires a serial port connection, which my laptop does not have. I bought the USB to Serial convertor cable that Ken Mosher (creator of Turbolink) recommends, but can't get it to connect. If anyone has any insight into this, it would be really helpful. Perhaps I should start a new thread to see if anyone has any insight into this Turbolonk issue.
