PYPES users reviews?
Old Feb 14, 2012 | 09:19 AM
  #41
LD85's Avatar
LD85
My Band Clamps are not on tight so the mufflers are loose and crooked, I am working on getting everything straight before i clamp it all down, so I'll fix that tonight. Nothing was changed except the exhaust
Pypes w/Hi Flow Cats Idle
Magnaflow w/ No cats idle
The exhaust note is really softened by the Cats on the Pypes, the Magnaflow is more rumbly, but I have no cats on the Magnaflows.
Old Feb 14, 2012 | 11:03 AM
  #42
88BlackZ-51's Avatar
88BlackZ-51
I prefer the sound of the new exhaust Larry.
Keep me updated in regards to the pm I sent you.
Old Feb 14, 2012 | 11:32 AM
  #43
LD85's Avatar
LD85
It will be going to the tuner Friday for Tune and dyno
Old Feb 14, 2012 | 12:22 PM
  #44
TigerVette85's Avatar
TigerVette85
http://youtu.be/7bVRykRqz9s
Sounds great, definitely worth the swap.
Old Feb 14, 2012 | 12:41 PM
  #45
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I like the new sound better.
Old Feb 14, 2012 | 12:52 PM
  #46
ch@0s's Avatar
ch@0s
mee too
Old Feb 14, 2012 | 01:07 PM
  #47
LD85's Avatar
LD85
Thanks guys, I think the drone will be non existent as well,,
In the Magnaflow video, one side of the exhaust isplugged in one tube on each of the Magnaflow mufflers and it is that loud and the drone was bad unless I plugged 1/2 of each muffler with Stainless Steel Wool
Old Feb 17, 2012 | 11:17 PM
  #48
LD85's Avatar
LD85
Front X pipe is done it'll be drive-able tomorrow
Driver side is bottom & pass side is on top
Old Feb 18, 2012 | 11:31 AM
  #49
ch@0s's Avatar
ch@0s
Great job! I wish I had your skills. I bought some C5 Random Tech Cats they are too far in and the cats are too far back. I think I will end up cutting them something like this... How about i just send them to you you seem bored?
Old Feb 18, 2012 | 01:06 PM
  #50
LD85's Avatar
LD85
DUDE, its a tight squeeze under there, but my cat setup has ample clearance all the way around for air flow, the bottom of my tunnel has DEI reflector attached to it with small/short sheet metal screws, so heat should not be a problem.
Wish i was closer, heli-arc welding is actually quote simple to do, but you gotta have the equipment
Old Feb 18, 2012 | 01:23 PM
  #51
ch@0s's Avatar
ch@0s
I might need some of that depending on where the cats end up. When you get them in will you take some good pictures for me please?
Old Feb 18, 2012 | 04:38 PM
  #52
LD85's Avatar
LD85
Old Feb 18, 2012 | 09:02 PM
  #53
ch@0s's Avatar
ch@0s
That's beautiful!! Lets hear it.
I wish I had that much space. The manual gives you a lot more room.
Old Feb 19, 2012 | 02:30 AM
  #54
LD85's Avatar
LD85
True, the TKO is smaller and and also much lighter than the ZF as well, @ 60lbs less
Old Feb 19, 2012 | 08:07 AM
  #55
Rob31's Avatar
Rob31
This is what mine sounds like , Just a L 98 http://s25.photobucket.com/albums/c7...t=100_3210.mp4
Old Feb 19, 2012 | 06:18 PM
  #56
LD85's Avatar
LD85
Drove it a short distance today, no drone and nice sound, I am pleased with this purchase
Old Jun 20, 2012 | 08:55 PM
  #57
LD85's Avatar
LD85
Update
OK, when I put my Pypes cats on and had the car tuned, I dropped @ 25 TQ/HP based on my previous dyno, unfortunately, the dyno results were from 2 different dynos,, everyone says, "you'll drop @ 5 hp/TQ" well, mine "might have or might not have" dropped more because of the 2 different dyno results
so I bought a crank trigger and I will tune the car with FAST sequential injection and with the cats and have it dynoed.
Also, I bought a new X pipe and will dyno the car with FAST sequential and NO cats for a comparison...
My hope is that the Sequential tuning will reduce the smell from valve overlap and allow me to run with no cats as well, and potentially pick up some HP/TQ to get back to where I thought I was.
My car is being painted so I don't have the car and dont anticipate getting it back until mid next week at the earliest, then I will mount the crank sensor and phase the crank and rotor and begin the tune I expect this to be finished by the end of July if my business lets up some
to be continued.....
To PYPES users reviews?
Old Aug 3, 2012 | 06:17 PM
  #58
renegade69's Avatar
renegade69
Had my pypes system installed today, finally got rid of the ten year old B&B droners. I still have a smile on my face. I'm running TPIS headers into a 3" X-pipe into the 2.5" Pypes system, no cats. Sounds great.
Old Aug 3, 2012 | 07:55 PM
  #59
LD85's Avatar
LD85
Nice, I like mine a lot, I'm gonna remove the cats in the winter when I swap out the cam,, UNLESS, I can get it tuned with the crank sensor..
Congrats!
Old Sep 13, 2012 | 12:55 PM
  #60
LD85's Avatar
LD85
OK, I pulled the cats off and installed a FAST Crank Trigger for better fuel smell tuning with Sequential Cylinder tune.
1. No I don't have a before and after with dual exhaust w/cats and Bank To Bank and without Cats.
Dyno info coming soon.
