LS swap
Old Sep 6, 2013 | 07:20 PM
  #181
COPO's Avatar
COPO
Originally Posted by vettedan
Nice work fabing up the intake. One concern I have is you engine going to starve for air at the upper RPM due to reduce air volume.
I built a LS1 up to 430HP, one issue i had was the small diameter LS1 MAF. I went to an 6.0 L truck MAF and it made a huge difference above 4500 RPM. I already put a larger TB before I changed the MAF.
Using the card. Not really worried about to much at this point. I've done my homework from mapping the turbo all the way down pipe size and length. Only thing I don't like is the 3 inch coming out of the turbo. I wanted 4 inch until a certain point where the exhaust cools enough to go back down to 3inch to keep a raspy exhaust tone but I've already stuffed it full and run out of room.
Old Sep 8, 2013 | 11:38 PM
  #182
vettedan's Avatar
vettedan
Sounds like you did your home work, Good work!
Old Sep 9, 2013 | 11:11 AM
  #183
Steve85's Avatar
Steve85
Cruise-In V Veteran
The LS3 PVC setup pulls the pressure not from the valve cover, but from the Valley cover. This is the cover that resides under the intake manifold, and sits between the 2 cylinder heads under the plenum. GM instructs the left side PVC port to be capped off. If your running an LS1 set up you can upgrade to an LS6 style PVC system by replacing the valley cover.
Dan
Vetteworks
Just did this on my 85 with LS1. Switched to the LS6 breather, and modified the valve cover. Was easy, will update my thread (in sig) when I get a chance...
Old Sep 14, 2013 | 02:49 AM
  #184
VeryUnoriginal's Avatar
VeryUnoriginal
Might be going down this route once I make my '93 stop and handle better.
Old Oct 21, 2013 | 08:13 PM
  #185
COPO's Avatar
COPO
Well....y'all ain't going to believe what I'm fixin to do....
Old Oct 21, 2013 | 08:18 PM
  #186
dclafleur's Avatar
dclafleur
New LT-1 Swap instead?
Old Oct 21, 2013 | 08:22 PM
  #187
COPO's Avatar
COPO
Lol..not even close. Totally opposite of what you could imagine
Old Oct 21, 2013 | 08:44 PM
  #188
ch@0s's Avatar
ch@0s
The Chicken Dance!!
Old Oct 21, 2013 | 09:01 PM
  #189
COPO's Avatar
COPO
I can see you doing that dance. Its a done deal, started ordering parts today.
Old Oct 21, 2013 | 09:19 PM
  #190
MeanMachine350's Avatar
MeanMachine350
St. Jude Donor '12
454 swap?
Old Oct 21, 2013 | 09:46 PM
  #191
ch@0s's Avatar
ch@0s
Cool, what did you order so far.
Old Oct 21, 2013 | 09:51 PM
  #192
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
230hp, Iron headed L98?
Old Oct 21, 2013 | 10:25 PM
  #193
COPO's Avatar
COPO
Originally Posted by MeanMachine350
454 swap?
Close number
Black round things
Put a 1 in the front
Old Oct 21, 2013 | 10:31 PM
  #194
dclafleur's Avatar
dclafleur
440? Going with more than one turbo too?
Old Oct 21, 2013 | 10:50 PM
  #195
1993C4LT1's Avatar
1993C4LT1
Curious to find out.
Old Oct 21, 2013 | 11:34 PM
  #196
STEVEN13's Avatar
STEVEN13
Solid Axle?
Old Oct 22, 2013 | 05:28 AM
  #197
COPO's Avatar
COPO
It's a thought
Originally Posted by STEVEN13
Solid Axle?
Yes. Isn't it ironic that tomorrow there is suppose to be a new casting to replace the Dana 44 sitting at the shop
To LS swap
Old Oct 22, 2013 | 07:08 AM
  #198
STEVEN13's Avatar
STEVEN13
Hi COPO,
Are you going to do a complete back-half?
My 92 is almost completed. I went with a 9" Alum center-Strange Housing with wishbone locator.
Good Luck! Looking forward to seeing your finished result.
Regards,
Steve
Old Oct 22, 2013 | 12:57 PM
  #199
COPO's Avatar
COPO
No plans on a full back half due to what I plan on doing.
Have a thread on yours.
Old Oct 22, 2013 | 01:35 PM
  #200
dclafleur's Avatar
dclafleur
Doing a whole new replacement chassis?
