LS swap
Old Aug 2, 2013 | 02:03 PM
  #141
dclafleur's Avatar
dclafleur
Originally Posted by COPO
What is really sad is I haven't had a day off in 7 yrs...only missed 3 from being sick. Only vacation I take is to Corvette shows which I get to see some C4 buddies.
My 1st day off has been fun and its in the way. I'm ready to rock and roll.
I'm starting to accept that I'm just to dang busy to work on my car. My wife finally said screw it started a vacation without me. Consequently I'm going to stay up late and start on my car tonight...
Old Aug 2, 2013 | 02:46 PM
  #142
IAFF alumni's Avatar
IAFF alumni
Come see me and my C4 here:
http://www.corvetteweekend.com
Old Aug 3, 2013 | 03:49 PM
  #143
COPO's Avatar
COPO
Originally Posted by 1991Z07
Looks like she needs a bath..
It got one.
Work on it...made me feel better
That's a long way away. Mainly go with the shop to sell frames but its still a vacation to me
Old Aug 3, 2013 | 03:58 PM
  #144
ch@0s's Avatar
ch@0s
Very exited to see this thing come together. Maybe one of of these days us LS swappers can meet somewhere.
Old Aug 3, 2013 | 03:59 PM
  #145
COPO's Avatar
COPO
Put the old trans in to check fit. I like when bolts fall in the hole as if it was made that way
Some things get close. I do have a lil more room using the auto c beam. No worries on plug number 8. Just enough clearance on the ac compressor. I also used the truck balancer on the pulley setup.
I'm very happy today after it all fit after being built on a engine stand
Old Aug 3, 2013 | 04:06 PM
  #146
COPO's Avatar
COPO
I been to Houston.... long drive. Your turn
Old Aug 4, 2013 | 05:32 PM
  #147
COPO's Avatar
COPO
Ever since I sat the motor in the hood would not close. After I got it on the lift finally found my problem. The turbo was suppose to set where the smog pump was originally. It wound up about 1/2 inch forward of where I planned. I can rotate the housing and the hood close but the outlet is pointed in the wrong direction. No big deal just cut the hood and all is good. I just hate I planned one thing and it winds up into another project to fix.
This is the most that's been put together. The lift made my life much easier. Radiator condenser and inter cooler are almost installed. Will be working on cold side and new and improved front air dam this week. Gotta keep momentum going on this
Old Aug 4, 2013 | 05:51 PM
  #148
dclafleur's Avatar
dclafleur
That's incredible, I appreciate the variety of skills you have to put into this. Something that required me cutting and redoing something on the hood would probably be a deal killer for me!
Old Aug 5, 2013 | 04:19 AM
  #149
bolowbc's Avatar
bolowbc
Are you going to do anything else to increase underhood airflow?
Old Aug 5, 2013 | 06:58 PM
  #150
COPO's Avatar
COPO
You don't learn unless you get out and do it.
Lots I want to do. Running and driving is top of the list. I am working on a new air dam. Just didn't like the way the other one looked...but it would keep the l98 cool going down the road even with the radiator half full.
Old Aug 5, 2013 | 07:57 PM
  #151
ch@0s's Avatar
ch@0s
True
Old Aug 5, 2013 | 08:27 PM
  #152
1991Z07's Avatar
1991Z07
Which Wilwood master cylinder is that?
Is the bias adjustable on the fly, or is that the **** next to it? Once you set it you're done?
Old Aug 6, 2013 | 10:07 AM
  #153
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Looking good and some awesome progress. Look forward to this custom air dam! Going to be running by weeks end?
Old Aug 6, 2013 | 10:33 AM
  #154
JimGnitecki's Avatar
JimGnitecki
GOTTA see this car finished!
Jim G
Old Aug 6, 2013 | 10:37 AM
  #155
LT4POWR's Avatar
LT4POWR
I'm lovin' the progress
Old Aug 7, 2013 | 02:24 PM
  #156
ScaryFast's Avatar
ScaryFast
What are your power expectations with the snail setup?
Old Aug 7, 2013 | 09:49 PM
  #157
gman35's Avatar
gman35
Default scoop source
I am looking to put a scoop of like yours on my c4.. is this a add on scoop or was it a complete hood.. would you possibly know where i could buy a scoop like this or a hood.. thanks gary
g_jorgensen@msn.com
To LS swap
Old Aug 7, 2013 | 10:12 PM
  #158
1991Z07's Avatar
1991Z07
g_jorgensen@msn.com
He made it himself...
http://forums.corvetteforum.com/c4-g...d-sanding.html
Old Aug 8, 2013 | 08:06 AM
  #159
S S0DEN's Avatar
S S0DEN
Looking good, I am interested to see how it runs...
Old Aug 31, 2013 | 02:16 PM
  #160
COPO's Avatar
COPO
It's the only one like it the wilwood makes. It could be adjustable if mounted inside the car
500 rwp should be fine at first.
I am working on it, just most I've done is unseen and fine tuning for fitting.
This is one of those pieces that can't be bought and takes hrs to make
