LS swap
Old Aug 31, 2013 | 02:25 PM
  #161
dclafleur's Avatar
dclafleur
Yes but the high end fabrication work you do is part of what makes this build so amazing to see!
Old Aug 31, 2013 | 02:30 PM
  #162
ch@0s's Avatar
ch@0s
I enjoy watching you work brother.
Old Aug 31, 2013 | 06:21 PM
  #163
COPO's Avatar
COPO
Some times I wish I was the guy who could just write a check for what ever I wanted
Come on over I got pizza and a beer or 12
After a couple hrs of weldind, part of it is finished. Will finish the cold side in the next couple weeks after I order a couplers and have it powder coated
Old Aug 31, 2013 | 07:19 PM
  #164
dclafleur's Avatar
dclafleur
Ha, I'm going the other direction, I'm approaching a point where I'm making more money working than I save working on my own cars. I'm thinking in another year or two I might shop around to have someone do an LS swap in my '85. I love the car, but I only get an hour or two every other week to work on it.
Old Sep 2, 2013 | 01:22 PM
  #165
COPO's Avatar
COPO
Keep working and I'll sell it to you
Old Sep 2, 2013 | 03:31 PM
  #166
3D87C4's Avatar
3D87C4
I'm diggin' that intake...but don't show it to my mechanic. He just updated the intake tube on my swap. It's the last thing to be done, then it's finished!!!
Old Sep 2, 2013 | 04:28 PM
  #167
1993C4LT1's Avatar
1993C4LT1
Old Sep 2, 2013 | 08:27 PM
  #168
coothethird's Avatar
coothethird
I may have missed it, but what accessory spacing are you using? I saw that they are a custom arrangement. I guess I am just asking what balancer fit? Truck? Fbody? Vette?
Did the rack you installed give you any more room in front of the engine?
Sorry for all the questions but I like the way it sits in there!
Old Sep 4, 2013 | 04:47 PM
  #169
coothethird
Did you have to change the drive shaft length? Or does the auto or manual drive shaft have enough slide yoke play?
Also, how much room do you have from the intake to hood? I am just wondering how much I need to raise the hood cowl on mine (Edelbrock Pro Flo XT).
Old Sep 4, 2013 | 10:06 PM
  #170
COPO's Avatar
COPO
I am using the truck balancer. Stock rack..the rack posted earlier will not be in the shop. Had one break.
Haven't got to the drive shaft yet. More than likely I'll make a new one.
If you can give me a couple weeks to get the front finished, I can give you some exact measurements. That's a tall intake and moving the engine forward will make the front of the hood worse. How much taller is it vs stock?
Old Sep 4, 2013 | 10:16 PM
  #171
COPO's Avatar
COPO
Congrats on getting it done. I buzzed through you thread a couple times, but as usual never have enough time.
Old Sep 4, 2013 | 10:38 PM
  #172
ch@0s's Avatar
ch@0s
I'm going to have to rethink my PCV it gets in the way of the Wiper motor. How is yours routed?
Old Sep 5, 2013 | 12:52 AM
  #173
3D87C4's Avatar
3D87C4
I'm afraid I don't know. Here is the most recent photo of that side of the engine I have:
I'll ask the next time we talk.
Old Sep 5, 2013 | 08:07 PM
  #174
3D87C4's Avatar
3D87C4
I spoke with my mechanic, there are two reasons the PVC routing isn't an issue in my swap:
Their mounts position the engine further forward than other mounts so there is a bit more clearance.
The LS1 & LS3 PVC routing are different. I'm fuzzy on the details so will say no more.
Old Sep 5, 2013 | 08:20 PM
  #175
ch@0s's Avatar
ch@0s
I think I have it figured out. Thanks
Old Sep 5, 2013 | 08:24 PM
  #176
vettedan's Avatar
vettedan
The LS3 PVC setup pulls the pressure not from the valve cover, but from the Valley cover. This is the cover that resides under the intake manifold, and sits between the 2 cylinder heads under the plenum. GM instructs the left side PVC port to be capped off. If your running an LS1 set up you can upgrade to an LS6 style PVC system by replacing the valley cover.
Dan
Vetteworks
Old Sep 5, 2013 | 08:36 PM
  #177
ch@0s's Avatar
ch@0s
Dan
Vetteworks
For now I'm going to run it over the intake and swap to LS6 PCV later. Thanks Dan you have been a big help.
To LS swap
Old Sep 5, 2013 | 09:20 PM
  #178
vettedan's Avatar
vettedan
Nice work fabing up the intake. One concern I have is you engine going to starve for air at the upper RPM due to reduce air volume.
I built a LS1 up to 430HP, one issue i had was the small diameter LS1 MAF. I went to an 6.0 L truck MAF and it made a huge difference above 4500 RPM. I already put a larger TB before I changed the MAF.
Old Sep 5, 2013 | 09:24 PM
  #179
dclafleur's Avatar
dclafleur
With his turbocharger he might be going for more of a speed density type setup anyways.
Old Sep 5, 2013 | 09:34 PM
  #180
vettedan's Avatar
vettedan
I would be concerned with a real rich condition at the upper RPM's
